11-16-2012, 03:32 PM
#48
Originally Posted by BrokenBones
it was +4 today with a wind felt like 0 or +1 at cold as hell i couldnt ride for more than 5mins before my legs and hands started to freeze
i checked the RPM at cold start it was 2.25 - 2.5 RPM going between that back and forth for 5mins..before settling down at 1.5ish i think is that too high ?
I also have a power commander i dunno if that will make a difference at a high rpm like that
Yes, when you start it, if supposed to be above 2000 rpm.
Mine, its arround 2000 rpm or more, and then gets down and stays at 1200 rpm.
Maybe the power comander makes it little high?
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
