Can't get baffle out of yoshimura : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-11-2012, 04:00 PM   #1
Just bought a 2006 with full yoshimura exhaust. Not loud enough. I took out the bolt holding the baffle in no problem, but I can't get the baffle out. I have tried:
thumbs
allen wrench hooked in the screw hole and pulling
allen wrench and hammer up from the hole of the screw
socket wrench handle wiggling around inside
socket wrench handle at an angle to try to pull it out
monkey wrench gripped on the lip (and now my baffle is kind of torn up looking)
It can wiggle a little bit, but just won't come out.
Any pointers? Anyone know how long the baffle is? Maybe I need something to hook to the back of it and pull??
I have already pulled so hard that the bike has come back towards me, which just seems wrong. I don't want to put so much strain on the mounting.
gnode is offline   Reply With Quote
Old 11-11-2012, 05:39 PM   #2
Marine 24/7
Felony RR's Avatar
Don't take out baffle, if you don't like it sell it find a louder one
2008 1k
Yosh Case Savers
-Oil Cap
-Triple Tree Stem
-Timing Cover
Renthal Soft Grips
Puig Smoked Screen
Vortex Block Offs
DDM hids
Custom Stitched Corbin Seat
Shogun Sliders
Hotbodies F/E
Smoked Tail Light
Galfer S Braided Lines F/B
Galfer Pads
Flapper Mod
PCV w/Custom Dyno
Arrow GP2 Slip on
ASV Shortys
Honda CF Gas Cover
CRG 2" Bar Mirror
Old 11-11-2012, 05:47 PM   #3
Why not? Is it not really meant to come out or something?
Old 11-11-2012, 06:24 PM   #4
Is it attached on the other end?
Sti2.5ldohc is offline   Reply With Quote
Old 11-11-2012, 06:37 PM   #5
COBRA90GT's Avatar
I would use a set of needle nose pliars. FWIW, here's what the baffle on one of my TRC carbon slip ons looks like from my RC51; might help to give you a reference point for what you're working with (YMMV, of course):
-Bazzaz Z-Bomb
-Flapper Delete
-HRC solo rear cowl
-HRC carbon fiber tank pad
-Honda Energy Seat
-Yoshimura FE
COBRA90GT is offline   Reply With Quote
Old 11-11-2012, 06:49 PM   #6
Goose
That's pretty much what the rs5 one looks like.
Might be able to use the spring puller over the end. Be careful not to damage the inside of the can.
Other than that; wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap, wiggle, tap....... Then repeat....... LOL!!
Shamizzle is online now   Reply With Quote
Old 11-11-2012, 10:26 PM   #7
Do you think there might be more than one screw? I removed the one at the back end of the exhaust that was clearly attached to the baffle. I don't see where another one would be.
Old 11-12-2012, 02:14 PM   #8
COBRA90GT's Avatar
^ Doubt it, the vast majority of exhaust silencers/baffles are usually held in place with one small hex/allen screw.
Chances are good that you probably have some carbon build up making the silencer "stick" to the inside of the canister. You're gonna need to use the proper tool for the job or get some stronger muscles. Use a "twisting" force to help break it loose.
Or, try removing the canister so you can put it on your work bench to get better leverage (vice clamps?) when removing the silencer/baffle from the canister.
Old 11-12-2012, 02:44 PM   #9
Thanks guys. I am going to try the flapper mod first and see how that goes. When I am in higher RPMs I think the exhaust sounds fine. But when cruising on the highway around 4-4.5k I am silent and that is the part I am trying to fix.
Old 11-12-2012, 02:53 PM   #10
Huge Member
MrDude_1's Avatar
hit the inside of it with a good healthy spray of real "non-environmentally friendly" brake cleaner...
that will break loose any carbon-gunk holding the thing together.
MrDude_1 is online now   Reply With Quote
