Fuel pump prime 06 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-12-2012, 02:52 PM   #1
Fuel pump prime 06
My fuel pump won't prime and I am stumped. The pump is good (bought a new one on eBay and tested it before installation. My relays tested good with a meter. My kill switch tested good with a meter. I jumped out my bas. There are no blown fuses. The pump is not getting voltage. Ground is grounding correctly.
I bought an 05 headlight harness from somebody who said it worked on his 05 and 07. Could this be the problem? I cannot think of anything else. Gauges function like normal, and the mil light does not blink.
I am desperate here guys, please help!!! I would greatly appreciate any advice I can get.
2012 Suzuki Hayabusa
2012 Suzuki Hayabusa LE
2003 Honda Rvt 1000r rc51 sp2
1976 Honda CB 550
foxracing06 is offline   Reply With Quote
Old 11-12-2012, 04:00 PM   #2
"Dremel-Smith"
JetFireRR's Avatar
Rather hard to see anything in that picture...
I'm going to take a guess and say that's the plug for the bank angle sensor which resides between the headlights. Your fuel pump will not operate without this plugged in and the sensor installed arrow-up.
The pump will try priming without fuel in the tank when working correctly... though that is not something I would recommend doing too often as the fuel in the tank cools the pump itself.
"Gotta' get that fixed...." Me
FS Thread: Ohlins-HRC-Arata-Yoyodune-OEM. Everything!
"Speed has never killed anyone. Suddenly becoming stationary , that's what get you." -Jeremy Clarkson
JetFireRR is online now   Reply With Quote
Old 11-12-2012, 04:40 PM   #3
See 1st post. Updated
1976 Honda CB 550
Old 12-07-2012, 04:04 PM   #4
Bump anybody? I am desperate
1976 Honda CB 550
Old 12-10-2012, 10:49 AM   #5
Figured out the problem! Cam sensor wiring.
1976 Honda CB 550
