Yoshi R77 Full Install help!!! wont line up - Page 3 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-15-2012, 09:25 AM   #21
twilson's Avatar
Originally Posted by RC-DEVIL View Post
i swear this yoshi has been the biggest pain! im just clean em with rubbing alcohol so they dont start looking awful
Not too bad once you do it a couple times
MODS: HRC Intake Stacks, HRC Cams, HRC Head Gasket, Yoshimura R-77 Titanium Full Exhaust, Power Commander III, Bazzaz Z-Bomb, Spiegler Brake Lines, Flapper mod, Smog Blockoffs, Woodcraft Clipons, Woodcraft Frame Sliders, Woodcraft Spools, Woodcraft Stator Cover and Case Saver, Taylormade Undertail, Custom Hidden LED Signals, Gilles as31gt Rearsets, Sato Race Hooks, most importantly Suspenion Setup, and Custom Dyno Tune.
twilson is online now   Reply With Quote
Old 11-15-2012, 09:29 AM   #22
twilson's Avatar
You are getting a custom map right?
Old 11-15-2012, 10:08 AM   #23
Admin
lexus rx's Avatar
long bladed flat head will pop the oem copper gaskets out. use a dab of grease or vaseline on the back of the new ones. that way when you push it into the head, they will stay. if you dont, they will fall out. the grease or vaseline will burn away once they get up to temp.
if you are using brand new gaskets and torque everything correctly, you should not have to use high temp silicone for exhaust leaks.
if you think the yosh is the only system that gives people problems, think again. most full systems are a bigger pain in the ass on this bike versus others.
http://www.superbikesupply.com
info@superbikesupply.com
828-287-2101-sales
FEED YOUR EGO!!
08 cbr 1000rr
07 cbr 600rr
ΜΟΛΩΝ ΛΑΒΕ
Old 11-15-2012, 10:18 AM   #24
twilson's Avatar
If you use gaskets on a street setup you will need to remove the right fan.
Old 11-15-2012, 10:45 AM   #25
Admin
lexus rx's Avatar
gaskets on a street setup? can you explain this? gaskets always need to be used. doesnt matter what you are doing with the bike.
also, you dont need to remove the fan. you can pull the fan off and bend the brackets that attach it to the radiator. that will allow you to move the fan far enough away to keep it from rubbing on the header.
828-287-2101-sales
FEED YOUR EGO!!
08 cbr 1000rr
07 cbr 600rr
ΜΟΛΩΝ ΛΑΒΕ
Old 11-15-2012, 10:52 AM   #26
twilson's Avatar
It says specifically in the instructions not to use gaskets. There is no need for them. I contacted Yosh to verify and they confirmed.
Old 11-15-2012, 11:02 AM   #27
Admin
lexus rx's Avatar
i have seen that. if you run a flange on one end and the head on the other, you are going to have a small amount of residual blowby. no way around it. having any amount of blowby can affect your a/f ratio reading if you are running a sniffer in the exhaust (custom map,etc.)
828-287-2101-sales
FEED YOUR EGO!!
08 cbr 1000rr
07 cbr 600rr
ΜΟΛΩΝ ΛΑΒΕ
Old 11-15-2012, 11:17 AM   #28
twilson's Avatar
True, maybe that's why my bike has the "Yamaha tick"?
Old 11-15-2012, 11:19 AM   #29
are these copper rings the gaskets? cuz them sucker are in there, so are we for sure yet that the yoshi does not need them? cuz once i take em off.....im not tryna get new ones
and lexus rx.....y didnt i think of just bending the rad fan bracket before im an idiot
Old 11-15-2012, 11:20 AM   #30
» Latest Forum Topics
Reccomendations for summer jacket
06-19-2010 09:40 AM
Last post by dlounge
Today 12:59 PM
42 Replies, 4,478 Views
Guess it's the stator on '05
06-04-2013 12:43 PM
Last post by Mxmeac
Today 12:59 PM
17 Replies, 240 Views
Lets see your girl on your bike?
09-06-2010 08:48 AM
Last post by MCPhotographer
Today 12:52 PM
256 Replies, 60,827 Views
Needed: Red/Black Upper Fairing 06-07
06-11-2013 12:14 PM
Last post by Unreserved
Today 12:52 PM
3 Replies, 58 Views
BAZZAZ TOUBLESHOOTING
08-21-2009 10:46 AM
Last post by white wings
Today 12:26 PM
1 Replies, 223 Views
