I'm not sure if anyone run into this problem with there 2013 1000rr, but I want to ask is it harder to full throttle shift on the 1000rr?? ( shifting without letting off on the throttle) or once in a while it feel really hard to go from 1st to second?? Reason I'm asking is because I try full throttle shift on this bike and it seem a lot harder to do it, it wouldnt go to the next gear at higher rpm and once in awhile when I try to shift from 1st to 2nd around 30-55 it feel like Its stuck in 1st and would budge
Why are you even trying to shift without at least backing off the throttle like speed shifting ( not the best for your tranny unless done correctly all the time) OR why don't you have a quick shifter installed (better for tranny for speed shifting without backing of the throttle ie racers choice) OR why aren't you using your clutch when shifting? Your tranny probably doesn't like you very much right now and some day it's going to get even.
I second that
Even quick shifters, momentarily cut the engine off (fuel or ignition) to reduce the load on the gears before changing up.
I found the chain slack affects clutchless changes on my bike.
99.99% of times i use the clutch for 1st to 2nd. I guess if you are on a track or doing traffic light GP, then it would be different
I share the same comment as the others.. Why would you shift with full throttle? if you want to do that than get yourself a quick shifter. Smooth upshifts without letting off the gas!!!
Guys Calm Down, Full Throttle Shifting Still Use The Clutch, It Just Shifting At Full Throttle ( Sorry I Didn't Explain Clearly) And This Method Are Use Commonly On The Track For Drag Racing ( Sorry For The All Cap My Phone Doing It On It's Own)
I Drag The Bike On The track Weekly And Done It On Every Bike I've owned, But This Is My First Time Owning A Cbr So Not Sure If The Clutch Are different
Did your other bikes have slipper clutches? The CBR does. It may not shift smoothly if you're bouncing the engine off the rev limiter when you pull in the clutch at full throttle.
If you know what you're doing, CBRs are pretty much bullet proof. I have plenty of friends that turn them into dedicated track bikes
