Looking for a arm band or wrist band that will allow for me to mount a non-wide Garmin Nuvi 205 GPS to my arm.
I have looked and looked all over the Internet for one, but doesn't seem to be out there.
I would like to figure out the percentage of my 2006 CBR speedo off of actual MPH. I have a handlebar mount that worked perfect on my VTX, but there really isn't any room on my CBR bars to temporarily mount it to get the percentage.
I need to get the percentage so I can program my SpeedoDRD.
I have thought about getting some Velcro tape and mounting it directly to my tank on the flat spot, but I really don't like that idea as it would probably be a pain to remove later.
Anyone seen anything like what I described for a wrist band?
Any other ideas for temporarily mounting a GPS on the CBR?
I thought about a suction cup, but I don't think my Garmin came with one. Plus, I don't want it falling off while I am attempting to maintain 60 MPH for a couple miles. I guess I want guarantees and I know life don't work that way, but I hate seeing perfectly good working tech equipment breaking when it could have been prevented.
Do you know if a Garmin 205 would fit on that arm band?
You know what you are on to something. I have Velcro on my jacket sleeves. If I use some Velcro tape on the back of the GPS, it should fit nicely on my jacket sleeve.
i have my keychain garage opener velcroed between my fork and the frame. it will work. i was thinking velcro it to something solid but if you think itll work on your jacket go for it.
Just an FYI, I used the speedodrd calculator on the sight and it was DEAD on. I had a 200 rear tire. Just got a 190, so I need to re calibrate it with the calculator first.
is the 600rr tank metal? tank bag, with a plastic clear pocket. otherwise the center stem mount is always good, but you'll have spend $15 on a ram mount.
When I measured mine to calibrate my SpeedoHealer I just got up to speed, pulled the GPS out of my pocket, held it with my left hand near the speedo and observed the difference between the two. I didn't see any need to attach it to the bike. It is now dead nuts on at 70 mph.
I know you don't have a suction cup but someone else with the same question who Does have one may read through this for a suggestion. I've had no problems attaching the GPS suction cup mount over the plastic tachometer window on my bike (09 1KRR). Potholes do make me nervous but so far: no troubles. It should work well for a speedo check on a smooth stretch of highway (the digital speed readout is unobscured). Of course, make sure the suction cup and window are well cleaned before attaching.
