Clutch pressed in.. still wants to moves?
3K views 11 replies 8 participants last post by  djmixerx
#1 ·
I'm not sure how to describe this but when I press the clutch all the way in, and gas it feels like it will keep going. Same for neutral, if I gas it feels like its in gear. Sometimes when i'm at a stop it hard to get out of gear even if the clutch if fully in.
Do it need to bleed the system? Clutch going out? Slave cylinder or master going out?
#2 ·
Start by checking the adjuster position on the lever, you may not be getting enough
travel to fully disengage the clutch sometimes the adjusters get moved for one reason or the other.
If that does not improve anything put some fresh fluid in and bleeding the system,
start with the master and then the slave. If you are still having problems it's probably
time to rebuild the master and slave cylinders.
