Trying to put the front wheel chock in the right spot on a Harbor Freight 4x8 folding trailer. If you know the center of gravity of either of those bikes, please chime in. If you have a measurement you can pass along that you know works, pass it along. Need the data quick.
Trial and error, I find the contact patch of the front tire should be 17 or 18 inches back from the front edge of the deck. This is the 1100 lb capacity version of the Haul master.
In the absence of other data, if you put a set of scales under the front wheel and take note of the weight, and then do the same for the rear you could calculate the front/rear ratio which would assist in speeding up the trial and error process to find the balance point.
