where to mount nitrous nozzle in airbox : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 03-03-2007, 10:59 AM   #1
where is the best place to mount a nitrous nozzle in the airbox on a 1000rr. since it is one nozzle im not sure where the best place to mount it is. the liquid has to spray across all four of the air sensors. thenozzle doesnt spray in a straight line, the nozzle is set up so where the hole where the nitrous comes out isnt at the end it is about 5 mm from the end then it hits the end of the nozzle and in a way splashes it . im just trying to find the best place to mount. any help is appreciated
"ITS NOT WHAT YOU RIDE, ITS HOW YOU RIDE IT"
Honda 1000rr
TheDon is offline   Reply With Quote
Old 03-03-2007, 11:37 AM   #2
Toward the front of the bike, behind the two filters, centered in height should give enough dispersion. There's enough volume moved through the airbox that a full charge should get sucked in within the first 10 milliseconds.
dattaway is offline   Reply With Quote
Old 03-03-2007, 11:39 AM   #3
so there will be no problem with spraying the nitrous through the airfilter? i was thinking that would interupt the flow?
Honda 1000rr
Old 03-03-2007, 11:40 AM   #4
SV Racer
resuscit8u's Avatar
I wouldn't. I would go somewhere between the filters and the stacks
Jim
03 SV650S Track Only
#892 CCS MW Am/ASRA Pro
resuscit8u is offline   Reply With Quote
Old 03-03-2007, 11:44 AM   #5
im thinking where it is mounted the best way for the nozzle to be put at is perpendicular with the air sensors. so the spray goes out 180 degrees toward all the sensors? is this idea somewhat correct
Honda 1000rr
Old 03-03-2007, 11:46 AM   #6
SV Racer
resuscit8u's Avatar
I believe it is - yes, however, I am no expert.
Jim
Old 03-03-2007, 12:17 PM   #7
Ridin Again
Racerboyf1's Avatar
2006 CBR1000RR with lots of trick shit
The internet, it's serious business....
Racerboyf1 is offline   Reply With Quote
Old 03-03-2007, 12:28 PM   #8
SV Racer
resuscit8u's Avatar
Originally Posted by Racerboyf1 View Post
on nitrous that is.
Jim
Old 03-03-2007, 12:48 PM   #9
Ridin Again
Racerboyf1's Avatar
Ahhh, Check out my new sig.
Old 03-03-2007, 12:59 PM   #10
Internet Badass
adamballz's Avatar
good!
adamballz is offline   Reply With Quote
