What are my options - 08 1000RR is burning oil like mad? - Page 48 - Honda CBR1000 Forum : 1000RR.net
post #471 of 880 Old 09-22-2008, 08:44 PM
JimmyJam
PISS OFF!
JimmyJam's Avatar
Actually I got rid of that Harley 312R POS also. Constantly over heated, then the radiator was leaking, then a new rad started leaking. Numerous other problems to sad to mention about a 20K+ bike. Of course it followed the loss of my new 08 1KRR due to oil burning and multiple other problems with it as well.
Word of advice. Buy all your bikes with a credit card, because if they can't fix it, you can eventually force a refund.
I am currently owing 1 bike, a 08 ZX10R and it rides and runs perfect. Bought some BST wheels for it from Brad @ Superbike Supply last week. No longer miss the other bikes.
JJ
JimmyJam is offline
post #472 of 880 Old 09-24-2008, 02:00 AM
Baiazid
I went today to the honda dealer that sold me the motorbike and after a few phone calls to honda hq for Australia they decided to fill my bike with "honda genuine oil" + "genuine honda oil filter" and do a 1000km test then measure what's left
I will keep you in touch with this test next week when I will go there
Baiazid is offline
post #473 of 880 Old 09-24-2008, 03:35 AM
Daca
lelemud
Daca's Avatar
Admin says:
Very few 08s are having problems ..
Please keep us posted.
Daca is offline
post #474 of 880 Old 09-24-2008, 04:22 AM
Baiazid
Originally Posted by Daca View Post
Admin says:
Ok, but which ones?
How to tell before buy?
Baiazid is offline
post #475 of 880 Old 09-24-2008, 05:34 AM
Daca
lelemud
Daca's Avatar
Originally Posted by Baiazid View Post
Ok, but which ones?
It's a Russian roulette ...
Daca is offline
post #476 of 880 Old 09-24-2008, 10:35 AM
JUNGLEBOY
JUNGLEBOY's Avatar
Admin says:
Good luck Baiazid, I know Honda Australia did this for someone else and replaced it for them after doing the 1000km test when it was found to be using oil...
Hopefully they will do the same for you
2004 1000RR Racebike
05 Bottom End, 06 Head and Cams, Full 06 Akrapovic Evoulution Ti System with Carbon Hex Muffler, HRC/Kyle ECU, A-Tech intake, BMC Race Filters, PC3, Ohlins HO515 with HRC linkages, Forks-1.0kgmm springs/Race Tech gold valves, DIDERV3 with 15/45 Gearing,, JTR Corse slipper clutch, Vortex rearsets..
www.jungleboyracing.com
JUNGLEBOY is offline
post #477 of 880 Old 09-24-2008, 06:04 PM
Daca
lelemud
Daca's Avatar
Good luck. If you are from Sydney, Honda dealer from L Cove still plays game: .. who, what .. etc.
Daca is offline
post #478 of 880 Old 09-24-2008, 07:12 PM Thread Starter
djhartm
djhartm's Avatar
Ah the old '1000km' test....
Sad to see Honda is failing to step-up to the plate and quickly rectify the situation for those that are having legitimate problems. A compression, leakdown test, and inspection of the plugs will them all they need to know.
djhartm is offline
post #479 of 880 Old 09-27-2008, 09:28 PM
Baiazid
I have not ride my bike for 2 days and I wanted to recheck oil.
Something very interesting in oil checking method:
ENGINE COLD + BIKE UP STRAIGHT: Oil level FULL!!! About 90-95% above minimum level
ENGINE WARMED UP 4-5Min to 60C as manual specifies:
1 min rest up straight: oil level ZERO!!!
2 min rest up straight: oil level 10% above minimum level
5 min rest up straight (honda manual specifies): 30% above minimum level
6 min rest up straight: 40-45% above minimum level
20 min: 50% above minimum level
ENGINE WARMED UP to 100C after a quick ride:
1 min rest up straight: oil level: 75-80% above minimum level (quite a good value)
5 min rest up straight: oil level: 75-80% above minimum level (quite a good value)
Maybe oil check should be done at higher temperature to allow oil to come back.
Baiazid is offline
post #480 of 880 Old 09-28-2008, 08:01 AM
LorD ClockaN
Repsol Rider
LorD ClockaN's Avatar
so...
in this long topic..
did we get to conclusioN?
I think mine burns oil too......
I use motul 300V Factory Line 10/40 (they put it in on my first service check)
Maybe to use another oil brand?
sorry if this question is already answered here
Repsol '05
full modded - SOLD
'08 Winning Red!
R&G fender elim, R&G Fork & swingarm protectors, 4-Race Racing Windscreen, Full Akrapovic system Carbon, HRC ECU, Quickshiftter, Ohlins TTX rear, Front Ohlins catrige kit, HRC Throttle kit, BMC Race filter, Home made rearsets, Translogic dash, Brembo RCS 20x, SS lines, PAIR mod, EXUP removed, Flapper removed...
LorD ClockaN is offline
Human Verification
