fuel pump wont prime..... - Honda CBR1000 Forum : 1000RR.net
post #1 of 32 Old 04-05-2010, 12:32 PM Thread Starter
MJP91184
for some reason my fuel pump wont prime. everything is hooked up like its supposed to (I think) and the damn thing wont prime. its not throwing any codes or anything so idk what it could be except the fuel pump being bad. anyone have a clue?
MJP91184 is offline
post #2 of 32 Old 04-05-2010, 12:39 PM
dannyjenkins10
did you do anything to the bike?
dannyjenkins10 is offline
post #3 of 32 Old 04-05-2010, 12:42 PM Thread Starter
MJP91184
LOL ya. I completly disassembled it and painted mt frame and swingarm. then put her all back together.
MJP91184 is offline
post #4 of 32 Old 04-05-2010, 12:57 PM Thread Starter
MJP91184
any chance it could be bc of the ground wire? i have it bolted to the frame, but i didnt sand down the paint. i was thinking tht maybe its not grounding and therefor not priming? but would that throw a code at all?
MJP91184 is offline
post #5 of 32 Old 04-05-2010, 01:14 PM
sparkyz
sparkyz's Avatar
That could definitely be a good possibility. Sand down the paint anywhere you have a ground wire. I'm pretty sure that it would not throw a code for that. You can always just check for continuity between your negative terminal on the battery and the wire that is supposed to be grounding, to verify if it is grounding properly. There are other possibilities such as the bank angle sensor but I would start with cleaning up or at least checking those grounds.
08 CBR1000RR
03 YZ450F
sparkyz is offline
post #6 of 32 Old 04-05-2010, 01:17 PM Thread Starter
MJP91184
Originally Posted by sparkyz View Post
Definitely sand down the paint anywhere you have a ground wire. I'm pretty sure that it would not throw a code for that. You can always just check for continuity between your negative terminal on the battery and the wire that is supposed to be grounding, to verify if it is grounding properly.
who do you think you are using big words like "continuity".....? Ya that sounds like a good idea. Ima go sand her down and check her out. hopefully this will solve the problem.
MJP91184 is offline
post #7 of 32 Old 04-05-2010, 01:23 PM
Brentomatic
Lifetime Premium
Brentomatic's Avatar
Post a pic of this paint job.
Honda CBR1000RR - 2008.
Brentomatic is offline
post #8 of 32 Old 04-05-2010, 01:23 PM
wademade
wademade's Avatar
I had mine apart and it did the same thing. I just unhooked it from the fuel rail and pointed the end in a ratio rite turned the key on and by the second or third try it started to flow.Hooked it back up and everything was fine.
wademade is offline
post #9 of 32 Old 04-05-2010, 01:46 PM Thread Starter
MJP91184
I sanded down the frame and attached the ground like its supposed to. and still not starting. Its weird, I unplugged all my lower fuel injectors, and it didnt throw a MIL code. anyone have any ideas on that? i remember last time i put her back together, i forgot to plug them in right, and it didnt start and it threw a code.
Click image for larger version
Name:	001 - Copy.JPG
ID:	39774   Click image for larger version
Name:	002 - Copy (2).JPG
MJP91184 is offline
post #10 of 32 Old 04-05-2010, 02:20 PM Thread Starter
MJP91184
So I went out there, and it seems that every time I turn the bike on, and the kill switch is off, there is a little tick inside the fuse box (i think, either the fuse box or something near that). when the ignotion is on, and i turn the kill switch on and off, i can hear the clicking sound going off. dont know if that has anything to do with it. i also had a blown fuse. a 10A, it saiys on the fuse box that its for the horn and whatnot. dont know if thats related.
as you can see, im not so good with the eletrical stuff. any help would be awesome.
MJP91184 is offline
Human Verification
