04-21-2010, 08:32 AM
#10
Super Moderator
In my experience (on a 2006) the bike isn't real thrilled with being at 3K RPMs. I consider 3K RPM on the 1KRR to be nearly-lugging. The bike seems fairly content at about 3500 as long as you don't plan to immediately pin the throttle. If you want to be able to roll on and have decent response, like others have said, you'd want to be in the 4500-5500 range.
That said, if I'm cruising at a constant speed, I'm almost always in 6th gear -- unless being in 6th gear would put the RPMs below 3500. That means that sometimes you have to quickly click down a gear or two to get to the power. Given that, if I have any reason to think I'm going to need sudden throttle I'd stay in a lower gear.
I don't know that all of the above added anything to what others have already said -- but it's my two cents.
