new guy looking for help : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 01-08-2011, 11:25 AM   #1
chaseblk07's Avatar
hey guys,I just recently picked up a black and graphite 07 1000rr and I absolutly love this bike.the guy that i bought it from put a 2bros slip on and I myself have recently put a few mods on such as the bazzaz zfi and afm and a scorpio rlink alarm on it.my problem though is that i have a very limited space in my tail secion and I have ran out of room in my tail section now because of all the elctrnic devices I have so far.I want to get a quickshifter but i dont think the bazzazunit will fit,is there any other places i could put it?I dont think that there is enough room under the gas tank.if the bazzaz unit wont fit will the translogic unit be small enough?where is the best place to buy the translogic qs?i checked the superbike supply and it looks like they dont sell them any more.any help would be appreiciated
chaseblk07 is offline   Reply With Quote
Old 01-08-2011, 11:37 AM   #2
R1's suck! balls!
How did you get the Z afm on???
I have a 08 with a two bros pipe. It does not have a o2 censor. therefore the Bazzaz Zafm does not work on my bike with that pipe....
You must either have a different pipe
or you have not installed it yet
good luck I had o send mine back cause my pipe is not compatible.
08cbrcivicsi is offline   Reply With Quote
Old 01-08-2011, 11:40 AM   #3
unforgiven's Avatar
If you have an aftermarket exhaust, get the Exhaust servo bypass from pbruth and get rid of it. You can now use the servo tray under the battery tray. Not sure how big the Bazzaz is as mine has not arrived yet.
unforgiven is offline   Reply With Quote
Old 01-08-2011, 11:43 AM   #4
chaseblk07's Avatar
you can order the exhaust bung and have it welded on to the header pipe where it goes from the 4 into 1 peice,my local dealer is doing this as we speak
Old 01-08-2011, 11:47 AM   #5
chaseblk07's Avatar
thanks unforgiven,the bazzaz units are actually very small but my alram is what is taking the majority of the space right now.so far what i have fits in the tail but as for the qs much less anything else im stuck.theres no room under the tank from what i can see either
Old 01-08-2011, 11:47 AM   #6
Excellent Member
is there any other places i could put it? I dont think that there is enough room under the gas tank.
if the bazzaz unit wont fit will the translogic unit be small enough?where is the best place to buy the translogic qs?i checked the superbike supply and it looks like they dont sell them any more....
Slow down bro.... use some punctuation....
The Bazzaz QS is an integrated module that replaces the Z-FI you have; it will fit right in where your Z-FI is now.
Which ever you want, if you PM Lexus Rx I'm sure he'll be glad to hook you up either way you decide.
MikeCBR is offline   Reply With Quote
Old 01-08-2011, 11:48 AM   #7
R1's suck! balls!
Will it work if you weld the bung into the exhaust pipe?
It just seems to be a lot easier to do that then to actually weld it to the headers to me and for me to do.
also does anyone know if it would be better or worst to put the censor in the pipe or header??
Old 01-08-2011, 11:54 AM   #8
chaseblk07's Avatar
from my knowledge so far you can weld it to the slip on itself but you have to make sure that the slip on is made of a certain type of material for the welder to be able to attach it.im not a welder but this is what the dealer told me
Old 01-08-2011, 11:57 AM   #9
chaseblk07's Avatar
thanks mikecbr.sorry about my punctiation I know its a bit sloppy
Old 01-08-2011, 12:00 PM   #10
Excellent Member
No problem, man. It just sounds like you're talking real fast....
