reare brake weak? - Page 4 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-20-2012, 05:20 PM   #31
Originally Posted by piousbox View Post
Harro. I has a CBR1000RR and after like half a year I noticed that my rear brake is wayyy softer than front brake. I read this thread and thought there is air in my brake system so I went to the mechanic and he said, on literbikes the rear break is weak by design, because "if you lock up your rear wheel, you are dead." He said, 90% braking power is front, 10% is rear, and the rear brake is supposed to be used for speed modulation only. I had a Nighthawk before the CBR and on the nighthawk the brakes are super-snappy, like SNAP!!! and the wheels are locked. On a gixxer 750, also. But on the liter CBR it is not so. My mechanic says it is by design.
(BTW great forum guys, and great bikes. Good stuff Honda.)
Find a new mechanic lol thats the dumbest thing iv ever heard!!! Bleed your rear brake. Good as new. My back brake is fantastic and i never use it unlesss im covering it backing it in on the track. But you should never really use your rear brake on any sport bike were talking a diff of maybe 15 ft if you dont panic and stomp on it and everything goes well
Sent from my DROID BIONIC using Motorcycle.com Free App
If you arent on the track, i dont care what has been done to your bike!
ZxSixxeR is offline   Reply With Quote
Old 11-20-2012, 05:23 PM   #32
Well, he argued as follows: "look at the size of the front brake. Then look at the size of the rear brake." The front brake disk is huge and the rear brake disk is tiny. (I can send pics upon request.) Doesn't that mean that the rear brake is meant to be significantly weaker?
piousbox is offline   Reply With Quote
Old 11-20-2012, 05:44 PM   #33
noahb's Avatar
Obviously theyre different sizes, don't know If you noticed but there's two as well.
And yea comparing the two is like bicycle to motorcycle.
noahb is online now   Reply With Quote
Old 11-20-2012, 05:45 PM   #34
GligorovDimce's Avatar
When i bought the bike, my rear brake was weak, it could still lock up the rear wheel,but had to press a lot, like really a lot to lock it up.and then this year before i store bike for winter, i bleeded the brakes and i fucked up something and i get on street to try it and it was even worse. So i said i will look into.so i dissmounted the brake caliper, cleaned everything, pads, caliper,cylinders and put very small ammount of brake lube-grease on where pads slide and bleeded the whole sistem again and step by step i all bubbles were out and now i have very very nice brake, like its brand new.just touch it and brakes nice,press little more and locks up.
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-20-2012, 05:46 PM   #35
[QUOTE=piousbox;2123047]Well, he argued as follows: "look at the size of the front brake. Then look at the size of the rear brake." The front brake disk is huge and the rear brake disk is tiny. (I can send pics upon request.) Doesn't that mean that the rear brake is meant to be significantly weaker?[/QUOTE
Thats a terrible explanation. He is correct i guess but the way hes explaining it is wrong. That would be like saying there forks in the front and a shock in the back instead of vice versa?
Old 11-20-2012, 05:52 PM   #36
From ow.ly/fsgXn
"Most motorcycles that come with a rear disc brake use a smaller rotor than the front, and a smaller caliper too. Some cruiser bikes excepting. My bike for example has twin 310mm rotors in front, clamped by 6 piston calipers on each. The rear is a 240mm, clamped by a single piston. Obviously there is much less braking in the rear, and it's actually hard to lock up my rear brake."
Yeah well. Maybe I'm not doing a good job conveying what he said to me. Don't get me wrong, if you can convince me that I'm wrong I'll go bleed the rear brake, it's no problem ~__^
Old 11-20-2012, 06:19 PM   #37
Rocketj21's Avatar
If you don't have a firm feel to the rear pedal you have a problem.
Old 11-21-2012, 01:11 AM   #38
d207gp's Avatar
Has anyone taken the time to adjust the rear brake pedal position to its optimum setting?
Old 11-21-2012, 03:23 AM   #39
I tried i wasnt sure and i stopped before i damage something.
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
RR Swingarm Spools
12 V Outlet
Old 11-21-2012, 10:20 AM   #40
Huge Member
MrDude_1's Avatar
yes.
