Power wheelie fail..why? - Page 3 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-02-2012, 11:39 AM   #21
I'm 300lbs and had no problems with first gear power wheelies. You're not giving it gas hard enough. Lol. 2nd gear I had to go 50mph twist the throttle wot then let off and immediately back to wot and it'd rise up until I hit the limiter.
2007 1krr- "track whore" Akrapovic full exhaust, bazzaz zfi+QS/TC and autotune, vortex rear sets, Gpr damper, stainless braided lines, Penske shock, race tech forks
Adamcbr is offline   Reply With Quote
Old 11-02-2012, 11:44 AM   #22
Gunn IT's Avatar
I'll give you one suggestion that will work no matter what. I got this suggestion when I was learning to wheelie on my F3 back in 2001. After multiple disappointments at trying to wheelie, my dear friend suggested that I must install some BALLS. You may want to do the same. Pop the clutch man, that's way easier, but again it depends on person to person. Power wheelie... 1st gear, 9000rpm, chop the throttle to 4000rpm, and then GUNN IT again, the front wheel will come up. Keep your right foot ready for the rear brake just in case. But again, see if you can get those BALLS installed first; I had to.
2006 Honda CBR 1000RR (Current/Track)
2002 Honda RC51 RVT 1000R (Current/Street)
2001 Honda CBR F4i (Sold)
1998 Honda CBR F3 (Sold)
Gunn IT is offline   Reply With Quote
Old 11-02-2012, 01:13 PM   #23
Getafix's Avatar
Yeah i think i've heard of these balls you speak of. I also had a hard time doing wheelies & on my last trip i mysteriously grew these balls & hey presto it started coming up easily!
Getafix is offline   Reply With Quote
Old 11-02-2012, 04:57 PM   #24
GligorovDimce's Avatar
Originally Posted by JEBSR View Post
Different people like different things. I have seen way more people die and endanger others by driving fast than doing wheelies though.
You are right, but i dont drive fast on public roads.
My driving is my work, i drive semi truck for living.so speeding on public road not a good thing,one ticket,two tickets,three tickets and you lost your job-forever as a semi truck driver.
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-02-2012, 10:11 PM   #25
Thumbs up
awsome reply
codine is offline   Reply With Quote
Old 11-02-2012, 10:16 PM   #26
Originally Posted by Jmnismo View Post
You should come up no prob! Just take it slow! 1st can be very violent! Are you stock? And what year?
all stock '09 repsol
Old 11-02-2012, 10:18 PM   #27
Originally Posted by Jamin466 View Post
I'm about the same weight. I go about 40 mph and twist the throttle but not all out. I also give the handle bars a good pull and squeeze my legs around the bike. As for elevation difference I wouldn't know, I live in Oklahoma. I have a2010 with a slip on. I also don't like to clutch up wheelie, in second gear I do the same at about 80mph, hope that helps
Sent from my SGH-T989 using Motorcycle.com Free App
thanks
Old 11-02-2012, 10:46 PM   #28
will work 4 track time
redfactor's Avatar
I weigh 215 lbs and if i bring it to about 6500 RPMs in second and let off then give it a handfull the bike stands striaght up. I wont even do first gear wheelies on a 1000 because its too short of a gear and a lot of power. I do have a -1 counter sprocket though.
Sent from my DROIDX using Motorcycle.com App
2008 CBR1000 with some stuff
redfactor is offline   Reply With Quote
Old 11-03-2012, 11:45 AM   #29
I use to power wheelie but after practicing the clutch wheelie... I no longer power wheelie.... You don't get to enjoy it as much. Learn to clutch it man. I guarantee you wont regret it. 2nd and 3rd gear clutch wheelies is where its at. Definitely not 1st. When I first began doing it yeah I did it in 1st because it seemed to be the much easier option..
Old 11-03-2012, 02:44 PM   #30
AMPITUP's Avatar
This thread is silly. You have people saying buy a bigger sprocket, wheelie haters, ect. The secret is that you have a LITER BIKE. If you cannot twist the throttle in first gear and have it come up off of pure acceleration, something's wrong...and it's not the bike.
2006 600rr-SOLD
2008 1000rr-SOLD
2012 1000rr-CURRENT
AMPITUP is offline   Reply With Quote
