K&N Air Filter vs Stock Filter : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-03-2012, 10:48 AM   #1
Zedik's Avatar
Does any one knows what is the different between the following to K&N Air filters?
http://find.powersportsplus.com/?q=*...R%25CBR1000%22
Bike is used daily for street riding only.
1. Would I need to re-set the ignition mapping because of the greater amount of air that will flow into the air box after installing this?
2. Is there a better aftermarker air filter?
3. Would you just use the stock air filters instead?
2006 Silver 1000RR Stock
Zedik is online now   Reply With Quote
Old 11-03-2012, 11:06 AM   #2
d207gp's Avatar
If you want a good reusable aftermarket filter, I would choose BMC (street version) over K&N. You'd see optimal benefits with remapping, even with a slip-on, but not as much as you would with a full system. What are you running exhaust-wise?
Old 11-03-2012, 12:24 PM   #3
Zedik's Avatar
Thanks, d207gp, I'm running a stock exhaust, on a fully stock street '06 1KRR. Would I have to re-map, or can I just run the filter with stock setup?
And is there a specific recommended BMC street version model? I found this on BMS website:
http://www.bmcairfilters.com/standar...16_d464_5.aspx
Old 11-03-2012, 01:07 PM   #4
Ex-Everything
TheX's Avatar
You won't get any performance benefit with either filter.
2010 Aprilia RSV4 Factory
Mods: Lots of track days and large testicles
TheX is offline   Reply With Quote
Old 11-03-2012, 01:25 PM   #5
Zedik's Avatar
Because my bike is fully stock?
Old 11-03-2012, 01:31 PM   #6
12 RED 1000RR "GINGER"
TheBigBankHank's Avatar
i pulled the screens off the stock and noticed a difference. then i tried a set of bmc race fillters and didnt notice much so i went with a set of k&n race filters and honestly they all felt the close to the same as the stock without the screens... there was slightly more pull off the low rpms but nothing to brag about
Buy 87 Octane.... Spend the money you save on Ohlins!
TheBigBankHank is online now   Reply With Quote
Old 11-03-2012, 02:03 PM   #7
Zedik's Avatar
question is - isn't any change of air amount to the air box, e.g. via air filter modification or aftermarket replacement, requires also changing the amount of fuel in the air-fuel mixture?
Old 11-03-2012, 04:48 PM   #8
more air flow = more dirt in your engine - if your not chasing a championship its not worth it
bionicman is offline   Reply With Quote
Old 11-03-2012, 04:48 PM   #9
d207gp's Avatar
Stay with stock.
Old 11-03-2012, 05:12 PM   #10
SRM
SRM's Avatar
Originally Posted by d207gp View Post
Stay with stock.
+1
SRM is offline   Reply With Quote
