Putting Nose back on my 2004 need help : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-04-2012, 09:48 PM   #1
BrokenBones's Avatar
hey guys I need some help
I seemed to forgotten which bolts go in the bottom left and right corner of the nose
the pic above, its the bottom right corner where the flat black piece is theres a hole and from the diagrams ive seen
http://www.bikebandit.com/houseofmot...2026#sch310499
11 is the nut and 14 is the bolt
my question is.. where does the nut go between that flat black piece and the nose fairing.. or does it go behind the nose/ upper cowl stay ?
and I have no clue which bolt exactly do I use does anyone have a picture of it
is it black or a silver bolt ?
BrokenBones is offline   Reply With Quote
Old 11-05-2012, 09:44 AM   #2
"Special ladies are hot"
shocker69's Avatar
Should be blackish in color and the rubber nut grommet is on the upper fairing that has the turn signals on them.
It bolts into the far forward hole on these pieces.
Marchesini's, Ohlins rear, Ohlins RT's, 520 DID conversion, CRG levers, PCIII, Stomp Grip, flapper mod, Nicky cover, BMC race filters, Arata Box style slipon, Alth rotors, Galfer stainless steel brake and clutch lines Sato rearsets, 8k HID's, Puig DB.
shocker69 is offline   Reply With Quote
Old 11-05-2012, 11:39 PM   #3
so wait a minute
right now my bike is stripped of all fairings and I am putting them back on so far I only got the tail and the gas tank shell on...
are you saying that I need to put on my upper / middle fairings on first before I can put the nose fairing on ?
Old 11-06-2012, 12:02 AM   #4
shocker69's Avatar
Nope. Mount the headlight faring and then mount the side fairings. The side fairings will slide into the nose and then bolt them up once you get them aligned. I normally will not tighten down any of the bolts until I get the upper and lower fairings aligned, just get the bolts started and make sure everything is aligned and then tighten everything up.
Old 11-06-2012, 12:07 PM   #5
but wait on the diagram it shows the rubber nut grommet goes into the upper cowl behind the grill plastic bracket.. so is there another nut at the turning signal fairing that also gets bolted down ? lol sorry for so many questions
Old 11-06-2012, 05:56 PM   #6
shocker69's Avatar
It's ok. Stop looking at the diagram. When you mount the nose and then when you go to mount the upper middle fairing with the turn signal it slides in behind the hole you were asking about and the bolt goes through the nose and screws into the fairing with the turn signal. Look at your fairing with the turn signal and look at the very far forward hole above and forward of your turn signal. There should be a rubber grommet type thing with a screw hole that is where the bolt will screw into. It should look just like the rubber grommets you on your windshield too.
Trust me it will make perfect sense when you actually go to mount the fairings. It's like putting a puzzle together and there is not really a way to fuck it up.
» Latest Forum Topics
My ex
Yesterday 10:43 PM
Last post by TYSTYX
Today 01:42 AM
16 Replies, 94 Views
Map Masterlist
08-27-2006 07:43 PM
by Slvr04
Last post by BBB1000rr
Today 12:51 AM
113 Replies, 42,522 Views
Quick n Cheap Garage Door Opener
06-08-2013 06:36 PM
by trevorb
Last post by Danyilboon9
Today 12:33 AM
15 Replies, 478 Views
Hahha wtf is this shit I found on...
02-28-2013 09:52 PM
Last post by cortayack
Today 12:31 AM
27 Replies, 943 Views
My upgrade
Yesterday 10:45 PM
Last post by Rocketj21
Today 12:12 AM
9 Replies, 74 Views
