Do you Roll with Nitrogen or Oxygen ???? - Page 2 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-06-2012, 06:48 PM   #11
SlvrR's Avatar
Originally Posted by bionicman View Post
I rotate air for the street & nitrogen for the track
Can you explain why? How do you get al the air out? Bikes don't have dual valve stems.
SlvrR is online now   Reply With Quote
Old 11-06-2012, 07:18 PM   #12
Mr E
Originally Posted by Steamboat View Post
I use both! Air contains roughly (by volume) 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.039% carbon dioxide... and it's free.
Air from your compressor comes with water vapor which condenses under pressure....hence the blow out of liquid water when you open the valve at the bottom of your compressor tank. Once that water is in your tire, it will transition from liquid to vapor as the tire temperature is increased and the tire pressure will increase more rapidly.
Nitrogen (from a gas cylinder) is essentially free of water. However, if you don't evacuate any water liquid/vapor already in the tire, you don't get the full benefit of the money you spent.
You could do the same thing with any pure gas (with b.p. << ambient temp.), but ideally you'd want to pick something like N2 that is inert and cheap. Otherwise an inline desiccant would filter water vapor out of the air from your compressor, but might not be any more cost effective.
Mr E is offline   Reply With Quote
Old 11-06-2012, 07:28 PM   #13
Huge Member
MrDude_1's Avatar
well... as a streetbike, my CBR will never see huge pressure changes because it will not have a large tire temp change....
and since its pressure is not only checked regularly, but also since the tires rarely last me more then a couple months...... Nitrogen is worthless to me.
