Help with 2012 electronic gauge cluster setup : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-05-2012, 11:40 PM   #1
Brutus82's Avatar
Just bought a 2012 1kRR and I need a down and dirty on how to setup the shift lights, how to see how much fuel I have left, avg mpg, etc.
Brutus82 is offline   Reply With Quote
Old 11-06-2012, 12:15 AM   #2
keving422's Avatar
It's in your manual, otherwise it's pretty easy.
- Press and hold SEL (top button) as you turn the ignition to the ON position
- (It's the first thing you get to change around at this point) ours the bottom button to change where your shift indicator will start flashing. Press top button when done
- Then it'll let you select the point at which your shift indicator will actually start to light up.
- For all the other stuff it's as simple as pressing SEL (top button) during normal operation
Sent from my SPH-D710 using Motorcycle.com Free App
keving422 is offline   Reply With Quote
Old 11-06-2012, 12:20 AM   #3
Brutus82's Avatar
Thanks, I'll give it a shot. What about fuel indicator? My 06 had one.
Old 11-06-2012, 12:39 AM   #4
keving422's Avatar
The indicator is the "gal" .. At full tank it'll read "0.0" and climb as you use fuel. Your main tank holds about 3.5 gallons. Once your main is drained it'll switch to your reserve and your indicator will start flashing. Your reserve holds about another 1.2 gal
Old 11-06-2012, 09:03 PM   #5
Brutus82's Avatar
Thanks. I need to know what's the best setup for shift indicators if I'm just doing city riding. What rpm range for each gear should I set it at?
Old 11-06-2012, 10:41 PM   #6
keving422's Avatar
Unfortunately you can't set the indicator for each gear. What i did for a while was keep the indicator in the mid range. I had it start flashing around 10k.
Old 11-10-2012, 07:59 PM   #7
Brutus82's Avatar
I tried to set the shift indicators. You can go from 0 to 13000 rpms. What rpm should I start out at to move to second gear?
Old 11-12-2012, 02:13 PM   #8
keving422's Avatar
You can really shift at any RPM range. Like i mentioned before i kept my shift indicator at the range of the power band for the streets. How aggressive do you ride? 10k was perfect for me
Old 11-12-2012, 04:41 PM   #9
Brutus82's Avatar
I set mine at 4000 and it blinks when I'm in 6th gear doing 56 miles an hour. I am going with trial and error to see what's best. When you initially set the rev indicator, you can set it 4-13000 rpms, and then do the 200 increments after. I thought that the 4000 is when you would want to shift from 1st to second and then you set the increments from gear to gear. Not the case I guess unless I'm doing something wrong or missing out on something.
Old 11-12-2012, 06:09 PM   #10
keving422's Avatar
Like i said you can't set the indicator for each gear
» Latest Forum Topics
Stock battery
Yesterday 11:05 AM
by Growl
Last post by Growl
Today 01:15 PM
11 Replies, 130 Views
Guess it's the stator on '05
06-04-2013 12:43 PM
Last post by DJOrlando
Today 01:05 PM
19 Replies, 240 Views
Reccomendations for summer jacket
06-19-2010 09:40 AM
Last post by dlounge
Today 12:59 PM
42 Replies, 4,478 Views
Lets see your girl on your bike?
09-06-2010 08:48 AM
Last post by MCPhotographer
Today 12:52 PM
256 Replies, 60,827 Views
Needed: Red/Black Upper Fairing 06-07
06-11-2013 12:14 PM
Last post by Unreserved
Today 12:52 PM
3 Replies, 58 Views
