06 1k Air Filter : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-07-2012, 12:33 AM   #1
06 1k Air Filter
Hi All
I Have a 06 1k that is due for a service and i have been speaking to the local honda store who have informed me that if i was to run an aftermarket airfilter's on my bike and the RS5 slip on that the bike would need to have a power commander added and tuned etc I am trying to work out if this is tru or not any suggestions for anyone would be great...
Reason for not wanting to get power comander and tune is I will be getting new manifold soon and looking for the D & D slip on and would much rather get it all done at once
WC1000rr is offline   Reply With Quote
Old 11-07-2012, 01:14 AM   #2
BrokenBones's Avatar
from what I understand an aftermarket air filter would make your ECU want more fuel.. more fuel that it programmed to deliver because its set to a stock filter that can provide x amount of air.. with aftrmarket more air will get in.. more air needs more fuel.. but it cant deliver so you need a powercommander to make the injectors deliver the fuel to match the air from the filter
i could be wrong
i dont know shit lol
BrokenBones is offline   Reply With Quote
Old 11-07-2012, 01:15 AM   #3
just stick with OEM filter ... upgrading to aftermarket wont exactly make any much faster anyways not worth it
me . i already have a powercommander and i still went with a stock filter
Old 11-07-2012, 01:20 AM   #4
twistingthrottlenz's Avatar
I also have a 06 1k and am contemplating aftermarket for 2 reasons:
1. The local Honda dealer sells stock filers for $250 and aftermarket is like $150
2. Aftermarket filters can be washable
Sent from my GT-I9300
twistingthrottlenz is offline   Reply With Quote
Old 11-07-2012, 01:51 AM   #5
"Dremel-Smith"
JetFireRR's Avatar
I have a few mint OEM sets I'm selling for $30-/ pair. Screw those prices!
Buy a set now and swap them out for your old set when it comes time to replace!
"Gotta' get that fixed...." Me
FS Thread: Ohlins-HRC-Arata-Yoyodune-OEM. Everything!
"Speed has never killed anyone. Suddenly becoming stationary , that's what get you." -Jeremy Clarkson
JetFireRR is offline   Reply With Quote
Old 11-07-2012, 02:18 AM   #6
How much for shipping to New Zealand? Auckland 0629
Old 11-07-2012, 03:57 AM   #7
They are the same prices that i have been quoted here in aus also.. I guess the next question is installing a power commander worth it for a street bike that does very little track time???
Old 11-07-2012, 01:10 PM   #8
I cleaned mine at 18000kms, not too bad if you've got a compressor with an airgun attachment. Tap them on the ground, top first, to jar loose the crud, then use the airgun to blow through the filter from the outside to the inside. It's easier if you have removed the mesh screens.
Or, I found this online: http://www.wemoto.com/bikes/honda/cb..._filter_hiflo/
It's a pattern part, so I can't comment on it's quality, but it's cheap!
CBRmikeRR is offline   Reply With Quote
Old 11-07-2012, 03:20 PM   #9
wait what 250$ for filter ?
on my 2004 there are two cylinder filters at 40$ each.. I paid 80+13% tax from local honda dealer
its true with k and N u can clean the filters but the oem filters should last about 15.000kms no problems thats a long time
also like you said with aftrmarket filter you will be forced to get power commander (not a bad thing) because your injectors / ECU wont be able to handle all that extra air and fuel ratio
