tighten both front and rear axle nuts to 70 ft-lbs : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-07-2012, 03:30 PM   #1
BrokenBones's Avatar
I was installing my front and rear wheels today and I didnt know the torque spec by heart and I put both nuts on to 70... I figured that since most cars at 80 - 100
so putting a 70 on motorcycle seemed right
now I searched and it said 58 for front
should I untighten it half a turn ? or is it ok to leave them at 70 ?
BrokenBones is offline   Reply With Quote
Old 11-07-2012, 03:57 PM   #2
why not back it off a bit and retighten to 58 with a torque wrench?
Dsking86 is offline   Reply With Quote
Old 11-07-2012, 03:58 PM   #3
I used blue tread lock.... I rather just leave it unless its important that it goes down to 58 from 70
Old 11-07-2012, 04:00 PM   #4
d207gp's Avatar
Wheel bearings are not designed for excessive side loads.
Do it right. Loosen and retorque to correct specs.
Old 11-07-2012, 04:53 PM   #5
Social Assassin
jerrel's Avatar
Why does this guy keep posting stupid questions? If u tightened it too much then loosen it, if u can't be bothered loosening it then don't ask!
jerrel is offline   Reply With Quote
Old 11-07-2012, 05:19 PM   #6
GligorovDimce's Avatar
Rear axle nut on 2008 its 83 lbs.
2008 Honda CBR 1000RR
Silver-Black
HID Kit 6000K
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-07-2012, 05:34 PM   #7
Rocketj21's Avatar
Front axle = 58
Rear axle = 83
Also there is a specific order for tightening the front axle and pinch bolts and seating the axle.
You really need to get yourself a service manual so you know you are putting things back together correctly
Rocketj21 is offline   Reply With Quote
Old 11-07-2012, 05:37 PM   #8
BryGuy's Avatar
Buy a service manual and a proper torque wrench. 90 percent of the questions I have about my bike can be answered in the service manual.
I would check the front bearings and re install the axle to the proper torque setting. I would not use thread lock on the axle. I might use it on the pinch bolts, but that is it.
2010 CBR1000rr
"The journey is what brings us happiness, not the destination."
BryGuy is offline   Reply With Quote
Old 11-08-2012, 02:25 AM   #9
Very very cool, and thanks for the lesson! I love your unique ink!
Tinaphps is offline   Reply With Quote
Old 11-08-2012, 06:37 AM   #10
JM1
JM1's Avatar
RTFM!
JM1 is offline   Reply With Quote
» Latest Forum Topics
License plate location.
Today 08:44 PM
by Knarf
Last post by IOWNJUNK
Today 09:20 PM
1 Replies, 7 Views
Looking for a PCV map... '12 w/ r-77
04-10-2013 10:50 PM
Last post by jrmantia
Today 09:19 PM
9 Replies, 157 Views
The bike we all have been waiting...
Today 03:49 AM
by GFORCE
Last post by Fireblade61
Today 09:19 PM
7 Replies, 206 Views
Picked up an 08 600rr
03-16-2013 10:54 AM
Last post by Up2DTime
Today 09:00 PM
31 Replies, 871 Views
UFC
Today 07:31 PM
Last post by Skinjured
Today 08:59 PM
1 Replies, 9 Views
