Make your own heated vest/jacket : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-07-2012, 03:51 PM   #1
tyler500e's Avatar
I did!
I'm done freezing my arse off every winter so I had to give this a try. Everything you need should be available at Radioshack and Walmart.
I've heard of people sewing wiring onto a garment, but that seemed rather labor intensive and I'm not so skilled with sewing. I decided would try a different route, so I went by Savers and picked up a $5 windbreaker jacket with an inner mesh lining. I thought this way I could just weave the wiring through the mesh holes. At first I was going to just go the vest route, but I later changed my mind thinking I may as well have heated sleeves too. So I went by radioshack and got some 30awg teflon coated copper wire, some 16awg wire, battery connectors, 1/4 mono jack and plug for a "quick-disconnect" between jacket and bike, fuse holder, 10A fuse, a lighted SPST switch, and some heated shrink tubing. Total cost of materials came to around $50.
The resistance of this 30awg wire is about .1ohm per foot, and I went with about 30 feet to the tune of 3ohms of total resistance. Being that my motorcycle is 12 volts, 12 divided by 3 = 4 amps of draw. I went ahead and got a 10A fuse in case I decide to add heated pants or gloves later on.
I turned my fancy $5 jacket inside out and began threading the wiring through the mesh holes. I put the majority of the wiring in the chest and the anterior part of the sleeves since that's where the wind will hit me. I made sure to start and end the wiring near the same point to make adding connections easier.
The wiring is pretty difficult to see in this photo, but it's there. Once I was done placing the 30awg wire, I soldered it to larger 16awg wire and then (using fishing line, haha) stitched the bigger wiring into the jacket to secure it (in case I forget to unplug after getting off the bike) to prevent tearing.
Here's a better shot of the wiring.
Once the jacket was done, I put together the fuse holder and battery terminals and with the help of a dremel tool, mounted the switch near the left passenger foot peg.
I've been wearing the jacket inside out to keep from burning bare skin, but I plan to attach a long sleeve tshirt to the inside to better insulate the heated wire and to wear it correctly.
The jacket puts out a decent amount of heat with the bike idling and the draw from the jacket doesn't seem to affect anything else on the bike like dimming my highbeams. I busted out the multimeter to be sure. I tested the bike while idling with the jacket on and with my USB port charging my cell phone and voltage only dropped from 14.4 volts to 14.1 volts.
I don't know why I didn't do this years ago!
'A government big enough to give you everything you want, is strong enough to take everything you have..'
'12 CBR1000RR
FMF Apex exhaust, homemade Fender Eliminator, Vortex Rearsets, Yoshimura Case Savers, Motovation Fork Sliders, Rear Spools, Euro switchgear, wired USB port, wired connector and switch for heated jacket - all homemade and toasty warm
tyler500e is offline   Reply With Quote
Old 11-07-2012, 04:25 PM   #2
Jmnismo's Avatar
Wow! Nice Job man
Jmnismo is offline   Reply With Quote
Old 11-07-2012, 04:57 PM   #3
TYSTYX's Avatar
Ummm.... no thanks.
Sent from my M886 using Motorcycle.com Free App
My drinking team has a racing problem !!
TYSTYX is online now   Reply With Quote
Old 11-07-2012, 05:16 PM   #4
Looks good to me. Nice work.
Sti2.5ldohc is offline   Reply With Quote
Old 11-07-2012, 05:24 PM   #5
GligorovDimce's Avatar
Sounds nice,looks nice, would i wear it?? No.hope it will work out for you and hope you wont burn your ass.
2008 Honda CBR 1000RR
Silver-Black
HID Kit 6000K
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-08-2012, 10:49 AM   #6
MINI NSX's Avatar
I admire your effort but I'll stick with my hundred dollar heated vest.
'09 Vulcan 900 Custom Special Edition
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline   Reply With Quote
Old 11-08-2012, 11:54 AM   #7
I admire you creativity
cbr100rr is offline   Reply With Quote
Old 11-08-2012, 03:07 PM   #8
Huge Member
MrDude_1's Avatar
I did something similar years ago.
being that im both lazy and I wanted it to not look like a science fair project, I used "iron on" fabric to hold it on.. just lay the wire out, and then iron the fabric over it.. done.
then instead of that connector, I just used the same connector that every battery tender style thing uses.
most people dont know its not a several hundred dollar store bought liner... plus since it was done to the fleece liner of my riding jacket, it fits in it perfectly.
I need a new jacket, so I'll probably make another one in the future.
Old 11-08-2012, 03:46 PM   #9
thats really cool....but you know whats cooler? a guy on fire riding a cbr1000
Old 11-08-2012, 05:17 PM   #10
mtmansl's Avatar
Creative idea...
CCS #33
CQC Motorsports
2011 CCS Midwest Rookies Cup GTO #1
mtmansl is offline   Reply With Quote
» Latest Forum Topics
04 05 rims
Today 04:27 AM
Last post by cbr_haggis
Today 04:27 AM
0 Replies, 6 Views
My 04 Fireblade build thread
05-29-2013 07:38 AM
Today 04:16 AM
24 Replies, 576 Views
Aussie 2005 repsol build#
Today 04:07 AM
Today 04:07 AM
0 Replies, 7 Views
Touch Up Paint for 2012
06-29-2012 04:43 AM
by Big D
Last post by shleeve
Today 03:53 AM
3 Replies, 301 Views
RIP 2012 CBR1000RR
06-07-2013 12:10 AM
Last post by Andy2091
Today 03:14 AM
48 Replies, 1,642 Views
