Damn, that is heart breaking response.
I'm not super surprised by it though.
I spoke with the engine builder. I asked about the reliability of the motor, things like valve clearance inspection intervals. He said the top end was pretty much stock and for street use, the maintenance intervals and reliability would be about the same as a stock motor. He did say that if it were raced, it would be much more like the 2k miles you mentioned.
What happens if you don't rebuild the motor? Do you just loose a little HP, or is like the rings completely fail and total loss of compression?? That's crazy to me that you can spend that kind of money on great components and a motor will only last such a short time.
I asked the owner if he'd allow us to meet at a shop so that I could pay for a dyno run to see current power (this was to actually verify engine work has been done oppose to taking peoples word). I figured if it was still putting very close to the 170 HP to the wheel it would indicate a good motor with work done. I'm around 5,000' here. It's also fitted with full Akropovic and a power commander. Does it matter if it wasn't raced and is still strong at +3,000 miles?
Thanks for the response, more are welcomed!
