No gear indicator here... : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-11-2012, 08:16 PM   #1
Hardcore's Avatar
This is about as many lights as you wanna see lit at once on your CBR1000. Oh wait a minute - that's not entirely correct. Another good one is that yellow flasher, "SHIFT!! SHIFT!!" at around 11-12. If you're seeing that one it's a party. But snap that picture holding your smartphone and you're a real psycho!
Not sure what gear you're in? Pay attention to the tach. I have learned all my sportbikes that way. Do you want to know how much it's gonna change if you run different profile tires, or change gear ratios, etc? NOT AT ALL. Honda senses speed at the engine, not the wheels. No mods to your gearing will change indicated speed vs. RPM.
If you're interested, here's how it breaks down on a CBR 1000, revs vs. MPH. These numbers aren't exact. MPH/Revs might be off by a few here and there, but for 6th gear this is very close:
4,000 RPM = 55mph
5,000 RPM = 70mph
Tach at 9 o'clock (under 6 grand) 80MPH
6,000 RPM = 85MPH
6,500 RPM = 90MPH
7,000 RPM = 100MPH
In 5th gear if your tach shows 12,000 you'll be somewhere over (over the rainbow!) 150mph.
I'll check this (it does get a little confusing) and if I'm off I will edit.
2009 CBR Repsol, 2nd owner
Yoshi R-77 full, SS shawty/Pirelli Angels/Hotbodies tail kit/Throttlemeister/CRG Spectrum Roll-A-Click shawtys/GB Racing engine covers/Honda eCushion seat/Carbone Lorraine brakes/Spiegler braided lines (orange)/Cox radiator guard/Radiator spaced for fan clearance/Engine Ice coolant/Dynojet PC-V/Dynojet IRC/K&N AF/Flapper mod
FIAMM Freeway blaster horns/Repsol 4T Racing 3L oil/SportRider suggested suspension settings (preload left stock)
Hardcore is offline   Reply With Quote
Old 11-11-2012, 08:23 PM   #2
supera's Avatar
Theres tons of aftermarket gear indicator though..for a low price.
supera is offline   Reply With Quote
Old 11-11-2012, 08:33 PM   #3
Admin
lexus rx's Avatar
disagree. a gear indicator helps quite a bit. absolutely loved mine on the race bikes.
http://www.superbikesupply.com
info@superbikesupply.com
828-287-2101-sales
FEED YOUR EGO!!
08 cbr 1000rr
07 cbr 600rr
ΜΟΛΩΝ ΛΑΒΕ
Old 11-11-2012, 08:55 PM   #4
noahb's Avatar
Are you saying changing sprocket teeth isn't gonna change my speed?haha. ..Your saying a stock(16F)(42R) sprocket set up running at say...5k RPM, will be the same speed as say..a -2(14F)(42R) at 5k.
And having a gear indicator would be much appreciated, I don't need something to tell me when to shift I can handle that (which you can set that stock light to start blinkin when you want it to)
Old 11-11-2012, 08:55 PM   #5
Agreed it does help a lot....also looks cooler too but Honda should of have made it standard starting at 08
08 Candy Red w/ Pearl [B]lack fairings
| CF Fender & Hugger
| Taylormade |
| BMC AF |
| Dynojet PCV & IRC |
| [b] ASV |
| [b] Vortex GC |
| [b] Gilles Tooling AS31GT |
| Competition Werkes FE |
| Galfers Lines |
| [b] Sato S/ Hooks |
| R&G Engine Slider |
| OEM Solo Cowl |
| Healtech GIPRO DS |
| '12 CBR1000RR wheels |
| '12 Digital Dash |
| Honda E*Cushion |
repsolRR1k is offline   Reply With Quote
Old 11-11-2012, 09:01 PM   #6
noahb's Avatar
Originally Posted by repsolRR1k View Post
Agreed it does help a lot....also looks cooler too but Honda should of have made it standard starting at 07
Haha there you go
Old 11-11-2012, 09:46 PM   #7
hahahha lol i mean 06 ^___^
| CF Fender & Hugger
| Taylormade |
| BMC AF |
| Dynojet PCV & IRC |
| [b] ASV |
| [b] Vortex GC |
| Galfers Lines |
| [b] Sato S/ Hooks |
| R&G Engine Slider |
| OEM Solo Cowl |
| Healtech GIPRO DS |
| '12 Digital Dash |
| Honda E*Cushion |
Old 11-12-2012, 05:32 AM   #8
Clueless & Happy
R1HOOLIGAN's Avatar
There's an excellent thread on installing a GIPRO gear indicator. Very simple and well worth it.
2008 CBR 1000RR
Yoshi exhaust, Gilles VCR Rearsets, GIPro Gear Indicator, ASV Levers, R&G Frame Sliders & Tail Tidy, Saddlemen Track Seat, Z/G D/B Windscreen, Harris Keyless Gas Cap, Sylvania SilverStar Ultra Headlights, Print Tank Protector, Honda Racing Rear Seat Cowl, Haynes Underbritches.
Plus, '08 ZX-10R, '08 Boulevard M109R LE, and
'08 Kawi T-Rex
'10 BMW S1000RR
R1HOOLIGAN is offline   Reply With Quote
Old 11-12-2012, 06:20 AM   #9
Ex-Everything
TheX's Avatar
Love gear indicators. The RSV4 has one stock, and also cancels turn signals after 90 seconds above 25 MPH. Seems easy enough.
2010 Aprilia RSV4 Factory
Mods: Lots of track days and large testicles
TheX is offline   Reply With Quote
Old 11-12-2012, 03:33 PM   #10
Hardcore's Avatar
INDICATED speed does not change
Originally Posted by noahb View Post
Are you saying changing sprocket teeth isn't gonna change my speed?haha...
Indicated my man, indicated speed will not change. Your mph to tach rpm ratio does not change if you regear. Your speedo is linked to your trans BEFORE your final drive. I know this because I regeared my 929 and the rpm/mph did not change. I didn't specify earlier but those RPM vs. mph figures I gave were for TOP gear, of course.
In fourth gear, when the tach is at 9 o'clock (slightly below 6k) the indicated speed is around 70, or down about 10mph.
In 3rd gear your indicated speed is more or less what your tach points to. If the tach says 3g's, your indicated speed is about 30mph. If it's at 4k, indicated is about 40mph and so forth.
I don't ride the track anymore, but I agree, a shift indicator is helpful if you're trying to make your best time. There's a lot to think about when your trying to hit your brake marker, set your line, etc. and a visual for your gear would be helpful, I imagine. On the street I could care less.
» Latest Forum Topics
Alpine stars
06-16-2013 10:34 AM
Last post by Runeknight95
Today 12:06 AM
8 Replies, 129 Views
Reccomendations for summer jacket
06-19-2010 09:40 AM
Last post by PeteBKK
Yesterday 11:52 PM
41 Replies, 4,419 Views
Word Association Game v2.1
12-06-2011 01:25 PM
Last post by Nopants!
Yesterday 11:34 PM
9,285 Replies, 126,056 Views
What did you do for your RR today?
10-19-2008 01:54 PM
Last post by Chrisj
Yesterday 11:27 PM
3,718 Replies, 182,108 Views
We got on the box with Kevin Schwantz!
Yesterday 08:51 AM
Last post by mtmansl
Yesterday 10:53 PM
5 Replies, 72 Views
