Hard to start : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-18-2012, 04:42 PM   #1
Hard to start
My 08 cbr 1000rr gives a lot of trouble to cold start. I changed the spark plugs and put new ones. A guy told me it was the injectors that needed cleaning. I used for redline fuel injector cleaner still no change. The strange thing is that if I jump start from a car battery or I push start the bike starts immediately. Anyone have any advice on how could I solve this issue.
Akins is offline   Reply With Quote
Old 11-18-2012, 05:04 PM   #2
BigRed's Avatar
Weak or bad battery is a possibility
BigRed is online now   Reply With Quote
Old 11-18-2012, 05:18 PM   #3
Rocketj21's Avatar
New battery
Old 11-18-2012, 05:51 PM   #4
What brand would you'll recommend cause I have a new one that never performed properly. I would also check the voltage on the present one. Thanks guys
Old 11-18-2012, 07:16 PM   #5
Rocketj21's Avatar
Just to confirm the battery condition take it and have it load tested.
If you want to check the voltage put a meter on the battery and record what you get with the bike not running, this is your battery voltage.
The battery voltage should be between 13 - 13.2V for a fully charged battery, less than 12.4V then the battery needs charging.
Then start the bike and recheck you should see an increase in voltage, this is your charging voltage which should be
greater than your battery voltage but less than 15.5V when checked @5000 RPM
If you do not see an increase in voltage with the bike running further troubleshooting of the charging system will be necessary.
Old 11-18-2012, 07:32 PM   #6
GligorovDimce's Avatar
Yuasa batery!!
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-18-2012, 10:33 PM   #7
BigRed's Avatar
What he said.
Old 11-19-2012, 10:43 AM   #8
put a multi meter on the battery
bionicman is offline   Reply With Quote
Old 11-19-2012, 11:00 AM   #9
+1 on yuasa
Old 11-19-2012, 11:07 AM   #10
d207gp's Avatar
Ballistic.
