Which Chain Breaking Pin To Use? Help! : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-21-2012, 11:29 AM   #1
I'm trying to break off the chain's master link and used a 3mm pin and shit broke already lol did a ton of research and there isn't anywhere that states which pin to use.
I tried to use the 4mm and it didn't work so i went to a smaller one. I want to preserve the chain so I am only trying to remove the master link off the chain.
Can someone help me here? Should I use the 4mm pin? and which side should i be pushing the pin through?
The riveted side? or the inside portion of the chain?
jojobrown is offline   Reply With Quote
Old 11-21-2012, 11:40 AM   #2
Eugene HRC's Avatar
You can either try to drill the pins head and then nock it out or use a grinder and gently grind the top part of the pin away .
Eugene HRC is offline   Reply With Quote
Old 11-21-2012, 11:41 AM   #3
i might just dremel the damn thing
