» Site Navigation |
» Motorcycle Forums
11-21-2012, 04:38 PM
#1
2007 CBR1000rr no fire/no fuel/no gauge sweep
Just picked up a cherry 2007 today from a widow whose husband had a heart attack. He bought the bike brand new, put 2776 miles on it and parked it in the summer of 09. Now i have it, after changing oil and gas, when i turn on the ignition the gauges illuminate but don't sweep. After you press the starter button and it begins to turn over they do there sweep, but it wont start, no fire or fuel, not even a fuel pump prime. While starting the hesd and the FI light are illuminated, then if you turn off the engine stop switch while cranking they turn off. I bypassed the BAS and tried again with the same results ecpect now the HESD and FI light do not come on. So i wired it back up and yet they did not come back on during cranking. Any help would be awesome, I just want to ride this thing.
11-21-2012, 05:17 PM
#2
Sounds like your fuel pump maybe gummed up with old gas.
Sent from my LG-VM696 using Motorcycle.com Free App
• 2007 CBR1000rr
• 2008 CBR600rr
• 2004 CBR600rr
• 1994 CBR600F2
• 1992 FZR1000
• 1990 CBR600F
• 1987 CBR600F Hurricane
11-21-2012, 05:22 PM
#3
Many are the weak...
no gauge sweep is weird.
Freedom should be removed from the dictionary and added to the history books.
"Every normal man must be tempted, at times, to spit on his hands, hoist the
black flag, and begin slitting throats."
-- H. L. Mencken
11-21-2012, 05:34 PM
#4
Its something small nut you have to find it.batery,fuses,ground spots.conectors.
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
11-21-2012, 06:22 PM
#5
Lifetime Premium
Sounds electrical, have you checked the battery? Check for burnt fuses, read voltages on fuses, rectifier, and stator... good luck! Curious how much did you buy the bike for?
04 Yamaha V Star 650
02 Triumph Daytona 955i
07 Honda CBR 1000rr
________________
"What can you ever really know of other people's souls—of their temptations, their opportunities, their struggles? One soul in the whole creation you do know: and it is the only one whose fate is placed in your hands."
11-21-2012, 06:29 PM
#6
Have you put a new battery in it, or have you re-charged the old one?
Kill switch maybe? I had mine fail to start a couple of times, traced the fault to the kill-switch contacts wearing. It was a while ago, but I think from memory, it turned over on the starter but wouldn't start. Wiggling the kill-switch, I could hear the pump run, then stop, then run again.
11-21-2012, 06:46 PM
#7
Okay, I replaced the battery and now the gauge sweeps properly but still no fuel prime or fire,I will start running those things down, and I paid 2500 for it.
11-21-2012, 06:52 PM
#8
Before I bypassed the BAS the FI light and HESD light were on while cranking, once I turned the kill switch off, while cranking, they went off and the would come back on after I switched the kill switch on. So I think that clears the kill switch of not working. Or am I wrong there. Also when I cranked it after i bypassed the BAS there was some smoke coming from the right side under the fairing, so i obviously stopped. It seemed to be coming from the component on the side in the aluminum case with the cooling fins? What is this piece? And what the hell did I do to it by bypassing the BAS?
11-21-2012, 07:24 PM
#9
After thinking about it, That must be the voltage regulator. How can i test it to see if its good or needs replacing?
11-21-2012, 07:54 PM
#10
Lifetime Premium
Lol nice brother, you practically stole it
07 Honda CBR 1000rr
________________
| Sponsored Links |
