Battery die in cold weather : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-22-2012, 09:31 AM   #1
Ryco's Avatar
Happy turkey day yall!
A few weeks ago on a cold night my bike battery died, I jumped it and it's been fine ever since. I even checked it with a battery tester the next day and the battery is strong, but I'm worried about it happening again. What do u guys do to protect your battery from dieing in cold weather?
Sent from my SAMSUNG-SGH-I317 using Motorcycle.com Free App
Ryco is offline   Reply With Quote
Old 11-22-2012, 09:48 AM   #2
Dragunslayer's Avatar
My bikes, atv, lawn mower, and my tractor live on Battery Tenders.
08' GL1800 w/ Full Monty (Traxxion Dynamics)
Dragunslayer is offline   Reply With Quote
Old 11-22-2012, 10:01 AM   #3
yep i use battery tender and have the quick disconnected wired to the battery. so its simply just plug and store.
08 Candy Red w/ Pearl [B]lack fairings
| CF Fender & Hugger
| Taylormade |
| BMC AF |
| Dynojet PCV & IRC |
| [b] ASV |
| [b] Vortex GC |
| [b] Gilles Tooling AS31GT |
| Competition Werkes FE |
| Galfers Lines |
| [b] Sato S/ Hooks |
| R&G Engine Slider |
| OEM Solo Cowl |
| Healtech GIPRO DS |
| '12 CBR1000RR wheels |
| '12 Digital Dash |
| Honda E*Cushion |
repsolRR1k is offline   Reply With Quote
Old 11-22-2012, 10:25 AM   #4
Ryco's Avatar
It didn't happen at home. I was at a buddies house for a few hours and when I went to leave it just wouldn't turn over. What can i do to combat that?
Old 11-22-2012, 05:07 PM   #5
phobos512's Avatar
Sounds like you might have an intermittent short in your battery, or a plate that's just hanging on. Since you're on a '12 I'd try a warranty replacement; failing that, get a new aftermarket battery.
phobos512 is offline   Reply With Quote
Old 11-22-2012, 06:09 PM   #6
noahb's Avatar
And battery tender,haha. That way you'll always know its at full capacity every time you leave
noahb is online now   Reply With Quote
Old 11-23-2012, 08:48 AM   #7
GligorovDimce's Avatar
Do you like them? Do they overcook the batery?
What brand are they? Can i see pic please? I am interested of getting one.
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-23-2012, 09:16 AM   #8
TY Bird's Avatar
Yes a battery tender this is the one I use...
Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive
You don't leave it on there all winter. Just let it charge for a few days at a time.
-2008 CBR1000RR
http://www.youtube.com/user/Birdriguez1/videos
TY Bird is online now   Reply With Quote
Old 11-23-2012, 08:21 PM   #9
TedEbear's Avatar
Here's what the description says about the
Battery Tender Jr Battery Tender Jr
. I have one on my '08 and it stays connected each day when I'm done riding, whether I'm going riding the next day or the next week. I still have the original battery in it, nearly 3 years old now.
The Battery Tender Junior 12-volt charger is much more than a trickle charger. It has a "brain". Utilizing a 4-step charging program (initialization, bulk charge, absorption mode and float mode), it allows you to simply connect the charger to a battery, either in or out of a vehicle, and forget about it until you are ready to put the battery to work. Like all Battery Tender chargers, at the end of the regular charger cycle it automatically switches its output voltage to a safe, storage or float level that eliminates the need to worry about the damaging effects of overcharging, and the resulting need to check on the condition of the battery. If/when the battery voltage drops too far under load, output power resumes and the charging cycle begins again. The unit also features sparkproof connectors, short circuit and reverse polarity protection, an easy to understand charging status indicator consisting of a single LED, and almost no current draw from batteries connected to it.
TedEbear is online now   Reply With Quote
Old 11-23-2012, 09:02 PM   #10
Hi MalteseSteeze!
utahphunk's Avatar
For the winter, I remove my battery and keep it in the house. (My garage is not connected to the house and not connected.)
But your situation sounds like a problem with the battery itself (which I'd agree, should be a warranty issue) or a charging system issue. Your dealership will test your battery for free.
utahphunk is offline   Reply With Quote
