Weird noise.. - Page 2 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-26-2012, 10:32 PM   #11
COBRA90GT's Avatar
Motul chain clean & Dupont Teflon Chain Saver here.
OP - It sounds like you need to keep up on your chain maintenance a little more (?), there's plenty of advice floating around on the 'net and on the message board about "how to" clean/lube and "how often" to clean/lube.
No matter what "method" you select, pick out a service schedule that fits YOUR riding needs and stick to it so your chain and sprockets will be happy.
-Bazzaz Z-Bomb
-Flapper Delete
-HRC solo rear cowl
-HRC carbon fiber tank pad
-Honda Energy Seat
-Yoshimura FE
COBRA90GT is offline   Reply With Quote
Old 11-27-2012, 12:43 AM   #12
Lifetime Premium
Visionary's Avatar
Thanks for the great advice guys. Cobra i definitely haven't kept up on the maintenance and will make a conscious effort to do so from now on, thank you
04 Yamaha V Star 650
02 Triumph Daytona 955i
07 Honda CBR 1000rr
________________
Visionary is offline   Reply With Quote
Old 11-27-2012, 03:23 AM   #13
GligorovDimce's Avatar
So its from chain, not from the wheel?
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-27-2012, 02:16 PM   #14
Lifetime Premium
Visionary's Avatar
So far that seems to be where the sound is coming from...heading to pep boys to grab some chain oil since my online order is lagging...Will keep ya'll updated on the problem after i lube and maintain my chain lol...How's you're situation? Did you fix your noise issue?
07 Honda CBR 1000rr
________________
Old 11-27-2012, 02:58 PM   #15
d207gp's Avatar
Originally Posted by BigRed View Post
I have always used WD-40 with no problems.
WD-40 is an excellent water dispersal (hence the "WD" part) and grease/grime buster since it contains solvents; I use it to clean my chain after a ride (although I prefer mineral spirits). However, as a pure chain lubricant it comes up short. You need something a little thicker that stays in the nooks and crannies to lubricate the o-rings. There is a good selection of specific o-ring chain lubes on the market. I prefer Maxima Chain Wax myself.
Old 11-27-2012, 04:21 PM   #16
Lifetime Premium
Visionary's Avatar
Thanks for the tips, was planning on using gasoline as the degreaser LOL but will pick up an extra bottle of wd40
07 Honda CBR 1000rr
________________
Old 11-28-2012, 12:02 AM   #17
Lifetime Premium
Visionary's Avatar
Alright guys i cleaned the hell out of the chain and the back sprocket and lubed it as well...the noise definitely toned down by a lot, but still a faint scratching/scraping noise coming from the bike...guess its better than nothing...ill clean my brakes and rotors this weekend hopefully that'll be the end of it. thanks for all the advice/support folks <3
07 Honda CBR 1000rr
________________
Old 11-28-2012, 02:01 AM   #18
d207gp's Avatar
Let us know how it goes!
Old 11-28-2012, 07:17 AM   #19
hyco_honda's Avatar
i've used a multitude of different cleaners and lubes. usually i get 12-15k out of a chain.
one of the guys on another forum recommended just using wd-40 period. this last chain swap i switched over to just it myself.
i've noticed the chain does not pick up near as much grit and grime between services when i just use wd-40. in fact it is so little i have to remind myself to service it. rim stays really clean, etc...
jury is still out on the life expectancy of the chain just using the wd-40 but i have noted the change in my service log.
Stay Thirsty My Friends
hyco_honda is offline   Reply With Quote
Old 11-28-2012, 12:44 PM   #20
Lifetime Premium
Visionary's Avatar
Sweet i'll keep that in mind
07 Honda CBR 1000rr
________________
