Weird noise.. : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-23-2012, 06:43 PM   #1
Lifetime Premium
Visionary's Avatar
Question Weird noise..
Guys i was driving in the canyons and noticed a weird noise every time i made a left turn. As i enter a turn i push down on the left peg with my toes and tilt my head towards the left mirror and notice a weird scraping/scratching noise, but dont notice the sound when making right turns....its an odd noise too soft to be a crazy scratch noise and too loud to be just moving parts...any idea what it could be? I'm scared to take turns fast now....
-could it be the engine? (sounds very similar to engine winding..)
-sounds more like my peg scrapping against the chain...
-Am i just being paranoid?
04 Yamaha V Star 650
02 Triumph Daytona 955i
07 Honda CBR 1000rr
________________
Visionary is online now   Reply With Quote
Old 11-23-2012, 11:33 PM   #2
GligorovDimce's Avatar
Now thats strange, check brake pads or chain.
I have strange noise comming up on deacceleration from front wheel.braking or no,pressed clutch or no,gear or neutral noise is there. Will check again sunday.my front tire pressure was 34 and i am heavy guy.i am 270 lbs
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-26-2012, 03:50 PM   #3
Lifetime Premium
Visionary's Avatar
Had a long ride yesterday and the sound is still there, sounds like a metal scrapping against something, done a lot of research and i highly doubt its the wheel bearing (apparently they're suppose to last a LONG time) my bike only has about 1500 miles on it....Noise only coming from left side (guessing front end) Any help/suggestions would be greatly appreciated
07 Honda CBR 1000rr
________________
Old 11-26-2012, 04:31 PM   #4
open the cover for the front sprocket and check that.did you put to much lube.
can you put bike and stands and try than?
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
RR Swingarm Spools
12 V Outlet
Old 11-26-2012, 05:38 PM   #5
Lifetime Premium
Visionary's Avatar
Im gonna check it out this weekend...unfortunately i work and get off in the evening by that time its too dark and cold to inspect anything...im going to get to the bottom of this soon enough
07 Honda CBR 1000rr
________________
Old 11-26-2012, 05:40 PM   #6
let me know what you have found out!
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
RR Swingarm Spools
12 V Outlet
Old 11-26-2012, 07:02 PM   #7
Lifetime Premium
Visionary's Avatar
Alright so i just put my bike on a front and rear stand and then rode 1st gear...seems like the chain is making the scrapping noise....ive only lubed the chain once since i purchased the bike at 350miles...im curious how often do you usually lube and clean your chain? also...what brand degreaser/oil chain do you use?
07 Honda CBR 1000rr
________________
Old 11-26-2012, 07:28 PM   #8
Supporter Of The Cause
SNEAKERHEAD's Avatar
Grease your chain every 300 miles. You should clean it when you see that its dirty. That's what I do. You have to keep the O rings lubed so they don't dry out.
SNEAKERHEAD is online now   Reply With Quote
Old 11-26-2012, 09:46 PM   #9
Lifetime Premium
Visionary's Avatar
Thanks sneakerhead! Recommend any brand name?
07 Honda CBR 1000rr
________________
Old 11-26-2012, 09:57 PM   #10
BigRed's Avatar
Purple power, gas or any heavy duty degreaser will work, dawn dish soap... Use the grunge brush? Not sure if that's what it's called, basically it's made for cleaning chains. Don't pressure wash the chain as it can ruin o-rings... As far as chain lube everyone has there own preference. I have always used WD-40 with no problems. I try and spray on every time I ride. It worked awesome on all my dirt bikes and those chains see some mud!
BigRed is online now   Reply With Quote
