Wierd problem on 2012 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-25-2012, 01:55 PM   #1
Ryco's Avatar
Weird problem on 2012
So the other day I'm riding on the highway at a decent speed and all of a sudden the throttle starts to get really choppy. The throttle cuts out for a half second and comes back on for a half second and the bike gets really jerky. I noticed it happens at 7000rpm. As I was coming from a stop light I stayed in first gear up to 7000rpms and the bike just shuts off. I coast into a parking lot and wait a minute and start it back up and finish my ride home with no problems. Yesterday the same thing happens as I'm about to get off the highway.
Has anyone ever heard of this?
Ryco is offline   Reply With Quote
Old 11-25-2012, 02:00 PM   #2
WhiteBikesRule!
Allmotor?'s Avatar
Never had that type of issue...is it throwing a code (check engine) when it's choppy?
Allmotor? is offline   Reply With Quote
Old 11-25-2012, 02:03 PM   #3
GligorovDimce's Avatar
Bad fuel maybe?
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-25-2012, 02:51 PM   #4
Ryco's Avatar
No lights are coming on when it happens
Old 11-25-2012, 02:54 PM   #5
Ryco's Avatar
Originally Posted by GligorovDimce View Post
Bad fuel maybe?
It was a new tank of gas from a different station when it happened the 2nd time.
Both times it happened after a little bit of spirited riding.
Old 11-25-2012, 05:23 PM   #6
Check the battery terminals for tightness?
gixxerjoe is offline   Reply With Quote
Old 11-25-2012, 05:32 PM   #7
Got Adrenaline?
TonyNYC's Avatar
I had that happen to my 2011 CBR1K the negative terminal on the battery was loose.
Check your battery connections.
2012 CBR1000
To My Beloved Father RIP, Love You Dad
TonyNYC is offline   Reply With Quote
Old 11-25-2012, 07:49 PM   #8
Ryco's Avatar
Will check it out in the morning.
Old 11-26-2012, 05:52 AM   #9
Did you fix it?
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
RR Swingarm Spools
12 V Outlet
Old 11-26-2012, 07:50 AM   #10
It does sound like it could likely be an electrical problem. I had a mini cooper with a bad ground wire on the battery do the same thing. Also, I had a bad crank position sensor in my STI once and it would cut out, shudder, and sometimes just die the instant it hit 4k rpm. If the battery connections aren't the issue, I'd take it in for warranty repair. Good luck!
Topher is offline   Reply With Quote
