URGENT HELP!! towing questions : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 01-03-2013, 11:10 AM   #1
BRoB1000RR's Avatar
hey guys im going to pick up my 08 1krr this next tuesday, my friend has a 6x10 wood floor trailer i plan on using.. i really need help with how to tie this baby down so it so it doesnt fall or get anything broke/scraped etc. i currently do not own any straps so let me know how i need to secure this baby. just straps? something to stabalize tires also? HELPPPPP
BRoB1000RR is online now   Reply With Quote
Old 01-03-2013, 11:21 AM   #2
D_M
http://www.discountramps.com/article...e-tie-down.htm
D_M is offline   Reply With Quote
Old 01-03-2013, 11:38 AM   #3
Milf Chaser
teedubyaw's Avatar
If you don't want to drop the money for some canyon dancers, then you can make do with ratchet straps from Walmart. The best way is to run a loop through the lowest part of the handlebars on each side, and slowly tighten down each one back and forth. Do not compress the forks too much, you just want the bike to be stabilized. Have someone sit on the bike (or you can sit on it) while tightening.
The rear isn't a huge deal. You just want to keep it stabilized. You can use the passenger pegs or the swingarm.
If you plan on hauling the bike a few times, I'd recommend going and picking up some canyon dancers, then a cheap wheel chock from Harbor Freight and bolt it down to a piece of plywood.
teedubyaw is offline   Reply With Quote
Old 01-03-2013, 11:42 AM   #4
Jorgie is da name..
1000rrk5's Avatar
These work great and the best out there IMO. Get the ones with the cups style, and some good straps, dont get the straps with half a hook those can come off. Here are some ideas.
the bottom pic is the one im saying not to get. see the difference on the hook style.
URGENT HELP!! towing questions-canyon_dancer_2_tie_down.jpg   URGENT HELP!! towing questions-picture-104.jpg
CMRA# 711
05 Repsol Ed. 1k....street
05 CBR 1k.............track
Endurance team "Ready or Not" #44
Endurance Team Bikes
03 EX 250 with stuff
97 CBR 600 with more stuff
BOOM
1000rrk5 is offline   Reply With Quote
Old 01-03-2013, 11:48 AM   #5
Go to Harbor Freight and pick up their wheel chock. Less than $40 and it will save your bike. Having it fall over on the trailer will cost you hundreds if not thousands.
2011 CBR1000RR
BigDogF250 is offline   Reply With Quote
Old 01-03-2013, 03:37 PM   #6
1 Fast Aussie
Aussiedc10's Avatar
Just use ratchet straps and route then under the fairing and wrap them around the bottom tree and fork tube. Make sure you're front wheel is pushed up against a rail, etc, and make sure the bike is in gear...
It's easy, cheap, and sturdy. I've been tying my bike down that way for years, never had a problem. And that equates to hundreds and hundreds of times tying bikes down that way...
-Fluffy
Aussiedc10 is offline   Reply With Quote
Old 01-03-2013, 04:20 PM   #7
noahb's Avatar
Ratchet straps and make sure your in gear..everybody has their own way to strap it down. Just use your common sense
Old 01-03-2013, 04:29 PM   #8
12 RED 1000RR "GINGER"
TheBigBankHank's Avatar
+1 on the wheel chock from H.F. and some canyon dancers and ratchet straps front and on the passenger pegs.. cant be TOO safe...
Buy 87 Octane.... Spend the money you save on Ohlins!
TheBigBankHank is online now   Reply With Quote
Old 01-04-2013, 05:49 AM   #9
GligorovDimce's Avatar
Wheel chock, ratchet straps x4 and didnt had problem from Cinci to Gatlinburg and back!
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 01-04-2013, 10:44 AM   #10
BRoB1000RR's Avatar
thanks for all the input guys, think ill spend $25 and get trailer with wheel chock built in from uhaul, then do at least 4x ratchet straps as well. i appreciate all your input and help! ill let you know how it goes when i get it back
