Anti-freeze? : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 01-08-2013, 06:18 PM   #1
Anti-freeze?
Global warming my butt.
Mind you, I live in San Diego. 2 of the last 3 nights have dipped into the 20's. 6 of the next 7 are forecast to dip into the 20's, most at 25. Daytime temps peaking at 50-55.
Bike is stored in a closed, attached garage. No heat, no insulation in the garage. I replaced the coolant with Maxima Cool-Aide (high performance coolant but no freeze protection). This was done by draining the system, then replacing with CA.
I've never lived anyplace "really cold" (and probably still don't), is that a low enough to worry about freezing and should I drain it and put in a regular coolant with freeze protection? Not what I want to do after work but I figured I would ask.
2011 CBR1000RR
BigDogF250 is offline   Reply With Quote
Old 01-08-2013, 06:28 PM   #2
COBRA90GT's Avatar
You'll probably be OK since the bike is kept inside the garage. The fact that the garage is attached will help out as well.
-Bazzaz Z-Bomb
-Flapper Delete
-HRC solo rear cowl
-HRC carbon fiber tank pad
-Honda Energy Seat
-Yoshimura FE
COBRA90GT is offline   Reply With Quote
Old 01-08-2013, 06:34 PM   #3
Ya, you're fine. It would take a couple days of it consistently below freezing for the inside of the garage (and the coolant) to get cold enough to do any damage.
2008 Murderrrred out
TM exhaust/undertail, Bazzaz zfi/zafm/zbomb
f3bk is offline   Reply With Quote
Old 01-08-2013, 06:50 PM   #4
Milf Chaser
teedubyaw's Avatar
I would not risk it in an uninsulated garage.
teedubyaw is offline   Reply With Quote
Old 01-09-2013, 12:20 AM   #5
TYSTYX's Avatar
It's hit mid 20's a few times here. I'm running water wetter and keep a digital thermometer sitting on my bike's tank. Never goes below 46 degrees in the garage.
Sent from my M886 using Motorcycle.com Free App
My drinking team has a racing problem !!
TYSTYX is offline   Reply With Quote
Old 01-09-2013, 05:58 AM   #6
Eugene HRC's Avatar
Cover your bike with a blanky or something
Eugene HRC is offline   Reply With Quote
Old 01-09-2013, 06:42 AM   #7
wloyd2k1's Avatar
You should be fine because of it being in the garage. On the front porch in the direct cold however would warrant definite concern.
wloyd2k1 is offline   Reply With Quote
Old 01-09-2013, 10:04 AM   #8
MINI NSX's Avatar
I don't think you have anything to worry about but if it would make you feel better put a 100 watt light bulb near the radiator or directly under the engine and cover the bike. The light will put off enough heat to keep it from freezing. They get hot, so don't put it too close to plastic.
'09 Vulcan 900 Custom Special Edition
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline   Reply With Quote
Old 01-09-2013, 02:00 PM   #9
Beantown Member
Miked617's Avatar
you'll be fine, if it was outside then yes id be worried...in an enclosed unheated attached garage you should be fine.
Miked617 is offline   Reply With Quote
Old 01-09-2013, 02:04 PM   #10
SamRR's Avatar
SamRR is offline   Reply With Quote
