So I have a custom map on my 06 1k and I changed the plugs yesterday and all 4 were fouled and I could smell the gas on them, so I think my fuel is running too rich anyone got any ideas or a custom map for k&n and 2bros slipon or should I just adjust it on the faceplate of the pc3usb? Do I only adjust the low end? Or the whole map?
You will never know how to adjust it properly until you put it on a dyno and see what it is doing throughout the RPM range.
It can be rich down low, and lean up top. Or vice versa.
Autotune, or Dyno. That's your options.
I left my bike stock, because it runs perfect like it is, and I would rather RIDE than mess with it.
Also, my bike has more power than I need like it is. So no reason for me to change it.
I wish I could look up the history of the maps that were on there cause when I got it, it ran beautiful I should have left it but I found a really good looking map and tried it and it ran good but not like before plus I added fuel on low end, I'm still re running all the wiring from taking the bike apart so when I get done with that I'll post what map I'm running, just so I don't foul them out again what would be a good baseline map for me right now, I'm in sc and I know it depends on sea level and a bunch of other stuff for the right map for your bike I just need something to hold me over till I can get in to dyno tune it
It's got low miles, it was running better than it is now I put the intake in and did the complete flapper mod now it's popping and won't stay in idle..............It's got to be something with the intake.
Custom maps are built on a dyno. You have a generic map or a map for someone else's bike and they usually suck. Get your bike on a dyno for a real custom map tuned to your motor.
Yeah I did the poor mans intake, I just fiberglass the intake and cut the fins inside but I just looked and I forgot to cut the whole out after I did the fiberglass so it's not letting any air out and everything is going through the system, at least that's my theory I'll see after I cut the hole
After you gut the stock intake and do the fiberglass
your intake should start to resemble the aftermarket ones pictured
below, just a big opening straight through no holes in the outer shell
Once you do the fiberglass you don't cut any holes.
I had all the holes covered but cut it out and took off the fiberglass I don't think I did the fiberglass that good, anyways as soon as I opened the air box I could smell gas really bad I'm starting to think I could have connected the two connectors for the spark plugs in the middle wrong mixed them up cause i didn't mark them and was looking at the harness and it looks like it but everything in the pic is how I have it, solenoid/canister/intake but I've never had these problems before so it's got to be the connection on the plugs or hose hooked up wrong or not hooked up, I only did the plugs and fiberglass the intake and that's the only thing I did and pc3usb has been installed since I've had the bike
Yeah it's plugged, that's why I'm scratching my head what it could be, what would be the symptoms if I didn't plug the right connections to the spark plugs back together(if I mixed the middle two)?
