2004 Gauges aren't working but it still starts : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 10-27-2009, 12:57 PM   #1
I was looking through the forum to see if somebody have encountered what i've encountered and the closest thing is the stator problem. I'm not sure if it is a stator problem, but i would like to have you guys input on this. I don't believe it's a stator problem because then the battery would be dead. The problem is some of the gauges are dead. The only thing working right now is the turn signal lights on the dash. I was letting my motorcycle warm up and all of the sudden everything went blank. The motorcycle still runs but when i turn the key none of the lights and tach move or turn on.
crazendisturbed is offline   Reply With Quote
Old 10-27-2009, 01:01 PM   #2
Kamikaze
philip1000rr's Avatar
Check the connection between the dash and the wiring harness. It may have become loose.
Originally Posted by douchebag View Post
you'll never out whore phil
Originally Posted by BigMattyD View Post
i hope you all die in fires.
philip1000rr is offline   Reply With Quote
Old 10-27-2009, 01:40 PM   #3
sixer's Avatar
fuse.
NESBA Mid-Central I-group #11
sixer is offline   Reply With Quote
Old 10-27-2009, 01:43 PM   #4
Kamikaze
Originally Posted by sixer View Post
fuse.
More probable than a loose dash connection.
Old 11-07-2009, 01:14 PM   #5
FUSE
Thanks everyone it was a fuse... ugh it's such a pain removing the plastic screw things.
Old 11-14-2012, 02:40 PM   #6
rav_in_sb's Avatar
Which fuse was it, I just had the same issue with my '07. Turn signals and high beam light up, everything else is dead on the dash.
rav_in_sb is offline   Reply With Quote
Old 11-14-2012, 03:06 PM   #7
Have you tried just going through all of your fuses regardless?
Old 11-14-2012, 03:19 PM   #8
COBRA90GT's Avatar
^ This - just check the fuses already.
FWIW I had the "meter/illumi" fuse blow on my '11 and had similar dash/speedo cluster symptoms (can read about it under the thread I created awhile back rav_in_sb). Same concept even though it isn't an '07 bike !
-Bazzaz Z-Bomb
-Flapper Delete
-HRC solo rear cowl
-HRC carbon fiber tank pad
-Honda Energy Seat
-Yoshimura FE
COBRA90GT is offline   Reply With Quote
Old 11-14-2012, 05:23 PM   #9
rav_in_sb's Avatar
It actually happened on my way to work today. I get off at 4:30 so I was hoping someone could save me a little work by directing me to the right fuse.
Old 11-14-2012, 05:43 PM   #10
winslo16's Avatar
Same thing happened to me. I blew like 10 fuses in a week and then it just quit.
Sent from my SGH-I997 using Motorcycle.com Free App
Not Impressed
winslo16 is offline   Reply With Quote
