Alternator Cover Removal : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 08-13-2011, 05:28 PM   #1
Got the 06 and I'm trying to replace its alternator cover. It's magnatized and a sealant and I'm tring to figure out the best way take it off. Flathead and force? Anybody done this before and have any suggestions?
Thanks
mds1000rr is offline   Reply With Quote
Old 08-13-2011, 05:30 PM   #2
ALFONSOMANCINI's Avatar
Thanks
The stator cover? Force it. Most likely gonna need a new gasket.
Sent from my Motorcycle iPhone app
ALFONSOMANCINI is offline   Reply With Quote
Old 08-13-2011, 05:36 PM   #3
Yuup, I've got the gasket. But damn, I guess this thing's going to need a lot of force. Have you done it before? What did you grip to?
Old 08-13-2011, 05:41 PM   #4
LeeterBike's Avatar
I used a flat head to make a little gap then used a plastic knife to spread it apart... Mine didnt have a gasket, it just hat rvt gasket maker
LeeterBike is offline   Reply With Quote
Old 08-13-2011, 06:06 PM   #5
I used a butter knife. Go around the whole case evenly. Slowly work around it
Old 04-21-2012, 11:06 PM   #6
Awesome Member
arrison24's Avatar
Where did you get the gasket for this? I don't see them for sale in OEM listings
2008 CBR 1000rr HRC Fireblade
2006 CBR 1000rr Konica Minolta- Sold
arrison24 is offline   Reply With Quote
Old 04-22-2012, 10:53 AM   #7
egf4998's Avatar
There are a couple of tabs around the edge of the stator cover that can be gently pried. It shouldn't take much force.
egf4998 is offline   Reply With Quote
Old 11-01-2012, 10:31 AM   #8
tyler500e's Avatar
+1
I would also like to know where to find a gasket for this..
'A government big enough to give you everything you want, is strong enough to take everything you have..'
'12 CBR1000RR
FMF Apex exhaust, homemade Fender Eliminator, Vortex Rearsets, Yoshimura Case Savers, Motovation Fork Sliders, Rear Spools, Euro switchgear, wired USB port, wired connector and switch for heated jacket - all homemade and toasty warm
tyler500e is offline   Reply With Quote
Old 11-01-2012, 01:19 PM   #9
When i replace mine on the 08 once i removed all the bolts. I just litely tap it all around w/ a rubber mallet to brake the seal from the HONDA BOND gasket sealant they use. Its magnetized so it wont fall off. You'll will be able to tell when its ready to just pull it off. You'll see it move freely. After i finish hitting it w/ the rubber mallet. i pulled straight out.
As for gasket..... I'm not familia on the 07 and below models. But as fas as i know they just use any type of gasket sealant maker. I opted to used the original stuff the HONDA BOND sealant it was like $5 online.
cbr100rr is offline   Reply With Quote
Old 11-01-2012, 01:31 PM   #10
Admin
lexus rx's Avatar
we have stator cover gaskets for the 04-07. we have clutch covers gaskets for the 04-12.
here is the link for the clutch cover gaskets.
http://www.superbikesupply.com/mm5/m...Category_Code=
info@superbikesupply.com
828-287-2101-sales
FEED YOUR EGO!!
08 cbr 1000rr
07 cbr 600rr
ΜΟΛΩΝ ΛΑΒΕ
