BIKE WHY YOU NO RUN?!?!?!?!?! : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 10-29-2012, 01:17 AM   #1
So I posteaboutd this up a while ago. Bike was having problems, the dash would go out after about 20 mins of riding. Rpm needle would not move when riding, no lights on dash and eventual bike would sputter out. Replaced stator and problem still occurred. Just replaced regulator/rectifier and took it out tonight. Bike did run for a while longer however, dash went out and bike again sputter out and died. This time the stator was spuing oil and it got all over the bike. I am officially out of ideas. Its a 2004 cbr1000rr
Artrek is offline   Reply With Quote
Old 10-29-2012, 03:33 AM   #2
GligorovDimce's Avatar
Start checking the wiring, no ground contact, or shortage!it must be something.
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-02-2012, 03:34 PM   #3
High_on_HUF's Avatar
http://i0.kym-cdn.com/photos/images/...hmifo1_500.jpg
High_on_HUF is offline   Reply With Quote
Old 11-02-2012, 04:50 PM   #4
try checking the cables that are close to the radiator they might have been clipped by the fans
Old 11-12-2012, 05:02 PM   #5
Brutus82's Avatar
A buddy of mines bike did this. We replaced his stator, rectifier and starter relay trying to figure it out. After all that we got it running but then it would drain new batteries like nothing. Turns out that he put the stator in wrong and it chewed up the wires.
Brutus82 is offline   Reply With Quote
