Front Sprocket Cover/Release Cylinder Removal : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 10-29-2012, 06:41 AM   #1
Blandino's Avatar
Today I replaced my chain along with my front & rear sprocket on my 2005 cbr1000. After I remounted the slave cylinder I was getting a lot of oil spillage from where the push rod is inserted. Is this just the seal needing replaced or is there anything else I should check before doing that? Seems odd that just from removing it and putting it back in I'd do enough damage to cause this much leaking.
Blandino is offline   Reply With Quote
Old 11-13-2012, 07:28 PM   #2
mutilate718's Avatar
if all u did was just change sprockets and chain... you probally damaged it when taking it off, replace it and if ur still leaking...ur guess is as good as mine good luck!!
''FASTER THAN A SPEEDING TICKET''
cbr1k 07 black, yosh slip-on, Kn fiters, Pclll, goodridge braided lines all around, 2ct's
mutilate718 is offline   Reply With Quote
