08 Won't Start : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-07-2012, 06:38 PM   #1
sparkyz's Avatar
08 Won't Start
All of a sudden my bike won't start, and I'm just looking for ideas before I get the time to start testing things. It cranks over just fine (connected jumper cables just to be sure), fuel pump is priming, but it never tries to fire. Modifications to my bike are only a PCV and a ZBomb which were installed about 3 years ago. I have not worked on the bike recently so nothing has changed.
Today while just doing some easy checks I did notice the exhaust does smell like fuel while cranking so I'm leaning towards ignition. I also plugged in the laptop to the PCV just to make sure firmware was still there and maps were there too. Nothing seemed out of the ordinary there. One thing I did notice was RPM never changed from 0 during cranking. Does anybody remember if their PCV shows any RPM during cranking? My initial thought was cam or crank position sensor and if it is supposed to show RPM during crank that would point toward that also.
Like I said before, nothing has changed with the bike in quite some time. I rode my bike about 3 weeks ago before hunting and now it will not start. It has never had any sort of problem or sputter or anything. It has also been covered and hasn't gotten wet.
08 CBR1000RR
03 YZ450F
sparkyz is offline   Reply With Quote
Old 11-07-2012, 07:28 PM   #2
GligorovDimce's Avatar
Fuel means unburned fuel! So no spark! Check the spark plugs.disconect batery and leave it arround 15 min to reset Ecu, then try.
Also to make sure, remove the power comancer and z bomb and then try.
It must be something minor, senzor,wire!!
2008 Honda CBR 1000RR
Silver-Black
HID Kit 6000K
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 11-29-2012, 07:17 PM   #3
sparkyz's Avatar
Looks like the culprit is the crank position sensor. I tested it the other day and got a max voltage of 0.6 volts and the manual calls for a minimum of 0.7 V. I haven't messed with the bike since then and just decided to try to start it today and was able to get it to start holding the throttle wide open and it still sounded like it had an occasional miss while running and would turn off if you revved it up and let off. After a while it got better and was running better so I retested the crank position sensor voltage and am now getting 0.8 volts all the time so that confirms that is the culprit. Guess I'll be ordering a new stator.
08 CBR1000RR
03 YZ450F
» Latest Forum Topics
wont start in gear
06-15-2013 09:03 AM
Last post by daveblank
Today 01:00 AM
16 Replies, 200 Views
Word Association Game v2.1
12-06-2011 01:25 PM
Last post by h8tossinit
Today 12:52 AM
9,229 Replies, 125,659 Views
Taylormade FE kit with LED tailight
06-14-2013 06:54 PM
Last post by d207gp
Today 12:38 AM
4 Replies, 121 Views
master link rivets
Yesterday 09:27 PM
by Spidey
Last post by TYSTYX
Today 12:15 AM
5 Replies, 48 Views
Rumble Concept Fender Eliminator 04 05...
07-11-2012 06:36 PM
by TiGGi
Last post by CBRIDERR
Yesterday 11:38 PM
6 Replies, 511 Views
