how do you get this 20p connector apart..... : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-10-2012, 10:31 AM   #1
isocyanates's Avatar
with out breaking it, its pretty snug, thanks in advance, john
isocyanates is offline   Reply With Quote
Old 11-10-2012, 02:19 PM   #2
TexasTraffic's Avatar
Find the latch and disengage. They all latch (or lock) closed.
Wiggle the two parts to loosen and separate.
2012 CBR1000rr
http://www.1000rr.net/forums/image.php?type=sigpic&userid=32823&dateline=133199  7534
TexasTraffic is offline   Reply With Quote
Old 11-10-2012, 02:40 PM   #3
I hate stuborn clips.
Sti2.5ldohc is offline   Reply With Quote
Old 11-10-2012, 02:56 PM   #4
shleeve's Avatar
It is a tricky one. The part that you squeeze is on the right side in the pic above the wires. The best way i have found to do it is to get some large pliers and grab latch and the small amount of plastic on the other side, and then pull the left side off from the right.
2012 CBR1000RR
Mods:
Honda E-Seat, Bikelitez taillight/license bracket/HID's, FireDragonBros rearsets, CF wrapped undertail, OEM Hugger,
OEM seat cowl, powdercoated wheels, Honda CF tank pad, Shogun sliders, Pazzo white/blue levers,
Driven red grips, Puig screen, Aluminum Leo Vince Oval EVOII, PCV, Exhaust and Intake Flapper mods,
PAIR removal, white marker LED's, chrome signal bulbs, SpeedoDRD, -1 front sprocket, Gorilla alarm system.
shleeve is offline   Reply With Quote
Old 11-11-2012, 07:57 AM   #5
thank you!
Old 11-20-2012, 11:42 AM   #6
Hardcore's Avatar
How do you get this connector apart?
At least 25% of my bitching and complaining in the "'08-11 cowl removal" threads was due to connectors. Once you get the darned plastic off, you have to contend with these things. And you want to just start bullying them but you know you have to be so careful. A tiny flat blade screwdriver helps to gently pry and separate while experimenting with what "could be" the release.
2009 CBR Repsol, 2nd owner
Yoshi R-77 full, SS shawty/Pirelli Angels/Hotbodies tail kit/Throttlemeister/CRG Spectrum Roll-A-Click shawtys/GB Racing engine covers/Honda eCushion seat/Carbone Lorraine brakes/Spiegler braided lines (orange)/Cox radiator guard/Radiator spaced for fan clearance/Engine Ice coolant/Dynojet PC-V/Dynojet IRC/K&N AF/Flapper mod
FIAMM Freeway blaster horns/Repsol 4T Racing 3L oil/SportRider suggested suspension settings (preload left stock)
Hardcore is offline   Reply With Quote
