Idleing way to high 06 cbr1000 please some one help : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-14-2012, 09:19 AM   #1
blade06
06 blade's Avatar
So I just bought a 06 cbr 1000 that has custom straight exhaust, but it has a sort of baffle in it, just no packing. It was idling fine,but once it got colder out, I got on it and it wouldn't drop any lower than 2 grand. I then tried adjusting the idle, it helped for about two blocks then it was right back to 2 grand. I had to ride the clutch to keep the idle down at stop signs. When i made it home i tried backing the idle screw out again it was 2 full turns and it barley affected it. Please some one give me some ideas.
06 blade is offline   Reply With Quote
Old 11-14-2012, 01:51 PM   #2
Sixty Four D Driver
johnnychimpo's Avatar
Mine does this too when it's cold out but goes back to normal when it warms up
I drive Sixty Fo' D's...F*U.
johnnychimpo is offline   Reply With Quote
Old 11-14-2012, 02:46 PM   #3
Marine 24/7
Felony RR's Avatar
My buddies 2010 idle was stuck at 10.5 which caused him to crash his bike...so we found out how to reset his bike... Put key in ignition, turn on off 7 times.. 7 times exactly! This worked on his bike which reset it to go back to usual "normal" idle try it out and let me know how it works out for u
2008 1k
Yosh Case Savers
-Oil Cap
-Triple Tree Stem
-Timing Cover
Renthal Soft Grips
Puig Smoked Screen
Vortex Block Offs
DDM hids
Custom Stitched Corbin Seat
Shogun Sliders
Hotbodies F/E
Smoked Tail Light
Galfer S Braided Lines F/B
Galfer Pads
Flapper Mod
PCV w/Custom Dyno
Arrow GP2 Slip on
ASV Shortys
Honda CF Gas Cover
CRG 2" Bar Mirror
Old 11-14-2012, 03:02 PM   #4
Was this something that was researched or you guys just so happened to try it 7 times and it just decided to work?
Old 11-14-2012, 03:06 PM   #5
noahb's Avatar
That's a 2010^, Someone call me out if I'm wrong but I didn't think electronics had anything to with the wax mold that the idle screw connects too..
noahb is online now   Reply With Quote
Old 11-14-2012, 03:06 PM   #6
Marine 24/7
Felony RR's Avatar
A track guru buddy of mine told us that it resets the bike... So we tried it and it worked.. Now by turning the bike key 7 times I do not mean starting the bike.. Just turning the key on off.
2008 1k
Yosh Case Savers
-Oil Cap
-Triple Tree Stem
-Timing Cover
Renthal Soft Grips
Puig Smoked Screen
Vortex Block Offs
DDM hids
Shogun Sliders
Hotbodies F/E
Smoked Tail Light
Galfer Pads
Flapper Mod
PCV w/Custom Dyno
Arrow GP2 Slip on
ASV Shortys
Honda CF Gas Cover
CRG 2" Bar Mirror
Old 11-14-2012, 03:09 PM   #7
Marine 24/7
Felony RR's Avatar
I'm not a mech nor do I claim it but we were trying to figure out why it was wide open and we just couldn't figure it out so a buddy suggested the 7 turn reset ad it just so happen to work and I was astonished that it worked as well I had no clue that there was a reset as such.
2008 1k
Yosh Case Savers
-Oil Cap
-Triple Tree Stem
-Timing Cover
Renthal Soft Grips
Puig Smoked Screen
Vortex Block Offs
DDM hids
Shogun Sliders
Hotbodies F/E
Smoked Tail Light
Galfer Pads
Flapper Mod
PCV w/Custom Dyno
Arrow GP2 Slip on
ASV Shortys
Honda CF Gas Cover
CRG 2" Bar Mirror
Old 11-14-2012, 03:46 PM   #8
noahb's Avatar
If it works, it works haha
Old 11-14-2012, 10:39 PM   #9
blade06
06 blade's Avatar
My idle stays the same even when its warmed please thrw me some ideas?
Sent from my SPH-D700 using Motorcycle.com Free App
Old 11-15-2012, 07:27 AM   #10
Sixty Four D Driver
Maybe your idle adjustment is stuck or its binding.
