Front axle torque - Page 2 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 12-01-2012, 05:21 AM   #11
TedEbear's Avatar
Originally Posted by GligorovDimce View Post
Any info how to remove front wheel please? Thank you
Still havent.there was thread here and cant find it. Need to remove front and rear wheel to check bearing.i have sound.
Here are a few threads on the procedure:
08 front wheel removal
Removing front wheel?
removing front wheel off an 08 1000rr
TedEbear is offline   Reply With Quote
Old 12-01-2012, 07:19 PM   #12
GligorovDimce's Avatar
Originally Posted by TedEbear View Post
thank you mister. still havent got a chancem today i was putting tires on the car and cleaning it, then putting lights outside for the kids and cleaned the truck.hope tomorow. hope will rain so i will work on bike in the garage!!!
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Bazzaz Z-FI
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 12-01-2012, 09:23 PM   #13
Originally Posted by CBRmikeRR View Post
Good call, 'cause I'm 100% certain Honda engineers sit around all day, drinking sake, and chucking darts at a board when they need a torque setting.
lmao! I spit up my sake while laughing at this
Grubeda7 is offline   Reply With Quote
Old 12-02-2012, 10:14 AM   #14
Clutch
Macko300exc's Avatar
Originally Posted by xxdevilzeroxx View Post
i put 40 frnt and 60 rear track setup
Originally Posted by d207gp View Post
Why torque to lower specs than factory? Just curious.
less tension more rolling
Better remove the brake calipers like guys that run dirt circle track. Brakes make your bike slower and you don't want that.
you can also crank the axle nuts as tight as you want, the spacers contact the outside of the bearing race not the inside and put zero preload on the sealed roller bearings. The bearings are not tapered like in older cars or large heavy trucks to where too much preload or tightness on the nut would increase drag. But iI'm not a Honda engineer what would i know
07 CBR 1000 RR
06 CBR 600 RR
09 KTM 300 XC-W
95 KTM 300 EXC
Macko300exc is online now   Reply With Quote
Old 12-03-2012, 12:11 AM   #15
I hope it didn't come out your nose.
CBRmikeRR is offline   Reply With Quote
Old 12-03-2012, 12:30 AM   #16
Orange County
xxdevilzeroxx's Avatar
because we are all experts =)
xxdevilzeroxx is offline   Reply With Quote
Old 12-03-2012, 12:56 PM   #17
hyco_honda's Avatar
yea, he must be cranking our axle nuts.
always torque to spec, apply loctite where required, etc. following the manual is a good idea
Stay Thirsty My Friends
hyco_honda is offline   Reply With Quote
Old 12-03-2012, 04:09 PM   #18
Clutch
always torque to spec, apply loctite where required, etc. following the manual is a good idea [/QUOTE]
Agreed. We may not know why, but that's the spec and that's what ill use for the procedure
SENT FROM A SMART STUPID PHONE
07 CBR 1000 RR
06 CBR 600 RR
09 KTM 300 XC-W
95 KTM 300 EXC
