Engine light flash : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 12-08-2012, 03:06 PM   #1
slimBjones's Avatar
Engine light flash
Hi to all,
I just came into possession of a beautiful 08 1000rr with under 8500 miles and after ridding under 300 miles myself the engine light flashes twice then comes the super ruff idle. I've checked all fluids and oil their fine the bike has PC3 USB, velocity stacks, full yosh r77, the problem started this morning during warm up before my ride...any ideas/suggestions
Thanks
Sent from my SGH-T989 using Motorcycle.com Free App
slimBjones is offline   Reply With Quote
Old 12-08-2012, 03:35 PM   #2
Qvo
Qvo's Avatar
Maybe wire is loose somewhere. Check the battery wires ( positive and negative) tight them up.
Qvo is offline   Reply With Quote
Old 12-08-2012, 06:56 PM   #3
slimBjones's Avatar
Unplugged battery for about 5 minutes no more flashing engine light and smooth idle is back...wired...thanks
Old 12-08-2012, 07:00 PM   #4
Qvo
Qvo's Avatar
Glad to help. Buy me a donut
Old 12-08-2012, 08:44 PM   #5
BigRed's Avatar
That isn't going to cure your problem, just like a car if you disconnect the battery for a while it will reset the memory but after a certain amount of drive cycles the light will come back on if it has a faulty sensor, meaning it will do the same thing if its a hard code bad tps, or iac sensor, fuel injector or whatever for that matter.
BigRed is offline   Reply With Quote
Old 12-08-2012, 08:45 PM   #6
BigRed's Avatar
Could be a loose connection as well.
Old 12-09-2012, 08:53 AM   #7
TedEbear's Avatar
If/when the flashing returns d/l a free pdf copy of the 08 owners manual and look up what the fault code is telling you.
TedEbear is offline   Reply With Quote
Old 12-09-2012, 10:33 AM   #8
slimBjones's Avatar
Funny u say that my girl used to work at Dunkin an still gets freebees...too bad she's in Bahiran(middle east)
Old 12-09-2012, 10:41 AM   #9
slimBjones's Avatar
I do plan on bringing it in for a check up but at least I know I can ride it to the shop without limping...thanks for the advice
Old 12-09-2012, 10:44 AM   #10
slimBjones's Avatar
Just did thanks
