Will a 2012 speedo work on a 2007? - Page 2 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Old 11-27-2012, 02:48 AM   #11
Horsepower Connection
common sense will tell anyone that it will not work without a lot of wiring changes etc... amazing the lack of thought people give things....
94 civic coupe track car 9.5@164mph
99 civic hatch daily 9.92@151
08 cbr 1000rr 9.3@151 E85 powered
2012 cbr 1000rr 194mph gps
The Horsepower Connection
hpc.derf. is online now   Reply With Quote
Old 11-27-2012, 09:49 PM   #12
Goose
^^^Or you could look into how it works and modify what's necessary....... Amazing how lazy/incompetant/boring people are.......
Alternatively, you can belive that all the fully sick modifications one can do are bought from Ebay, and bolt on directly with no other changes.......
Shamizzle is online now   Reply With Quote
Old 11-29-2012, 05:01 AM   #13
Would look great onto an 07 but you'll probably have to upgrade all your sensors as well!! Doubt they use the same after 2 full upgrades!!
Will need more wiring done as well I beleive.
Do a write up if you get it going?? Would love it on my 2010!!
VasRR is offline   Reply With Quote
Old 11-29-2012, 08:35 AM   #14
TexasTraffic's Avatar
Just to reiterate -
This is the way to do it.
Anything else is a leap of faith off a high cliff with the hope that someone strapped a 'chute to your back.
Originally Posted by puretone View Post
If the part numbers ain't the same, then no, it won't work.
I've done gauge-cluster swaps in Toyota cars...it is a bit of a pain in the ass. Keep in mind, the newer bike may use COMPLETELY DIFFERENT signals as opposed to your 2007 bike.
You can venture into this field by taking the first step:
1. Get the wiring diagrams for both bikes.
2. Spend a weekend ignoring all your friends, family, girlfriend, fiance, wife, boyfriend, cat?
3. During this weekend, stock up on coffee/redbull.
4. Find the wiring diagrams in the shop manuals, assuming you were a good boy & bought those ahead of time. There are different wiring diagrams....California & the rest of the states, Euro, Japan etc
5. Trace & identify all wires, mark them with a piece of masking tape on which you write what they are individually.
6. You will need to find a donor 2012 cluster & it's corresponding plugs/pigtails.
7. Spend some time identifying all the wires of the 2012 cluster.
8. Now you will need to figure out what kind of signals drive the 2007 cluster, in particular what kind of signal waves/pulses.
9. You'll need to find out what kind of signals drive the 2012 cluster (same as point [8] up ^^^ there)....you may want stop right here. Spoiler alert: I suspect this is where your venture will end. From what I can tell is that many of the vital signals will not be compatible. You could spend the next couple weeks/months figuring out how to gender-bend all the incompatible signals to get them to work with the new bike's cluster. Your ECU may or may not like any of this & will either complain or not work at all. The situation here is that you may potentially end up soldering in so many resistors, diodes & all sorts of other electronics to get some sort of compatibility. I'm not even sure if you can get the 2012 cluster plugs & pigtails....this would require them to be cut off of a donor bike's harness....junkyard *maybe*, but that would mean you will ruin an otherwise perfectly fine wiring harness.
The times that I have done it in cars, it has always been "similar" generation cars. By "similar" generation I mean the pre-CANBUS spec automobile wiring/sensor standards.
You could go completely extreme and do a full engine/wiring/ECU/gauges swap, but you might be better off just buying the new bike at that point.
2012 CBR1000rr
http://www.1000rr.net/forums/image.php?type=sigpic&userid=32823&dateline=133199  7534
TexasTraffic is offline   Reply With Quote
