Alrighty guys, i did the flapper mod according to the directions provided by rocket, thank you brother. So far i do feel a little bit more pull on lower RPMs up to 6-7k, and a smoother take off for sure. Thanks again!!
heres how i did it in case anyone wants to know where its located on 07 CBRs...
1) remove mid fairing
2) pull hose from diaphragm
3) put a screw in the hose (to not allow air in) and zip tie it (so the screw doesn't come out)
4) zip tie the hose somewhere away from heat/moving parts
My question is....do i have to put something to cover up the hole in the diaphragm as well? notice in the pictures after removing the hose its just open...
++ after doing the research the diaphragm should be left open as the picture shows for the extra air flow to the engine...(the whole point duhhh
**Don't mind the dead spider in the 3rd picture...lol
