12-28-2012, 08:08 AM
#13
Supporter Of The Cause
In 2nd I have my RPMs between 6 and 8k, I don't know my speed it's not relevant, then I SLIP the clutch and just hold the throttle in the same position. Once you feel the throttle slip let it go and your front end will jump up a foot or two, when it does just twist the throttle and it come on up. Keep doing this until you get the bike to it's balance point (it will feel like it's not there or it's weightless) keep it there with small adjustments of the throttle and PLEASE keep your back break covered so you can apply it if you bring the front too high. Don't slam on the brake though you will go over the windscreen just bump it. Good luck bro, don't give up you will get it to the balance point and remember what you did and try to replicate it. I hope this helps. Post us a vid once you get it.
2012 HRC 1000RR
Yoshimura R77 Titanium SO
BMC Race Filter
PAIR Mod
Flapper Mod
PCV
Z Bomb
O2 Eliminator
LSL Case Sliders
Puig DB Smoke Windscreen
Grey Renthal Full Diamond Grips
Hot Bodies Fender Eliminator Kit
Shogun Swingarm Slider Spools
Integrated Tail Light
ESRM Delete Chip
Street Hooks
R6 Throttle Tube Mod
More To Come
