Easiest speed to clutch up in 2nd? : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Go Back   Honda CBR1000 Forum : 1000RR.net > Stunt Riders > 12 o'clock
Like Tree1Likes
Old 07-24-2012, 01:54 AM   #1
CBRka's Avatar
I have an '08 1000RR and recently started clutching in 2nd, what's the easiest to speed to hold it up at for those who stunt the new bodys?
CBRka is offline   Reply With Quote
Old 07-24-2012, 05:53 AM   #2
Social Assassin
jerrel's Avatar
just practice dude. with enough revs u can clutch it up at 0 kmh
jerrel is offline   Reply With Quote
Old 07-24-2012, 12:21 PM   #3
winslo16's Avatar
For me is around 45, rpm between 4 and 5. I'd start with 4 and gradually go up
Sent from my SGH-I997 using Motorcycle.com Free App
Not Impressed
winslo16 is offline   Reply With Quote
Old 07-24-2012, 01:40 PM   #4
Rocketj21's Avatar
Yut Ughhhh, and remember always cover your rear brake!
http://www.ringburn.net/yutughhh/
Rocketj21 is offline   Reply With Quote
Old 07-24-2012, 03:06 PM   #5
Huge Member
MrDude_1's Avatar
uhh. go down the road and do whatever speed feels good.
anywhere from about 30 to 90+mph will work.. probably easiest around 60 or whatever speed puts the tach needle in around the 10 or 11 oclock position.
MrDude_1 is online now   Reply With Quote
Old 08-02-2012, 04:56 PM   #6
zippyd8's Avatar
Any speed should work in 2nd gear, but depending on where the rpm's are sitting will determine how much throttle you will need before you pop the clutch. for example if you are in the powerband of your rpm's you wont need as much throttle than if you were riding at 2000 rpm.
zippyd8 is offline   Reply With Quote
Old 09-24-2012, 11:32 AM   #7
neocryte's Avatar
For me, easiest around 60-65 mph in 2nd gear.
2008 CBR1000RR
neocryte is offline   Reply With Quote
Old 09-24-2012, 12:01 PM   #8
Marine 24/7
Felony RR's Avatar
2nd is pointless to clutch up big dog, go with 3rd and 6500 rpm and clutch away or try 4th (standing up in 4th) and clutch at 7500-8k rpms
Sent from your moms pager!
2008 1k
Yosh Case Savers
-Oil Cap
-Triple Tree Stem
-Timing Cover
Renthal Soft Grips
Puig Smoked Screen
Vortex Block Offs
DDM hids
Custom Stitched Corbin Seat
Shogun Sliders
Hotbodies F/E
Smoked Tail Light
Galfer S Braided Lines F/B
Galfer Pads
Flapper Mod
PCV w/Custom Dyno
Arrow GP2 Slip on
ASV Shortys
Honda CF Gas Cover
CRG 2" Bar Mirror
Old 09-24-2012, 02:57 PM   #9
Huge Member
MrDude_1's Avatar
why is second pointless to clutch up? You afraid of it coming up too fast and scaring you?
Old 09-24-2012, 03:05 PM   #10
Marine 24/7
Felony RR's Avatar
No it's just easier and if you can't find the balance these gears will last longer, I'll wheelie from 2nd to 5th shifting I'm just trying to help this guy so he doesn't loop it
BlackhawkBlade likes this.
2008 1k
Yosh Case Savers
-Oil Cap
-Triple Tree Stem
-Timing Cover
Renthal Soft Grips
Puig Smoked Screen
Vortex Block Offs
DDM hids
Shogun Sliders
Hotbodies F/E
Smoked Tail Light
Galfer Pads
Flapper Mod
PCV w/Custom Dyno
Arrow GP2 Slip on
ASV Shortys
Honda CF Gas Cover
CRG 2" Bar Mirror
