turn signals don't work and brake light doesn't work - Honda CBR1000 Forum : 1000RR.net
post #1 of 7 Old 04-24-2010, 05:33 PM Thread Starter
buster09841
My turn signals don't work when the switch is engaged. the front are lite but when the button is pushed they go out? the back just don't blink at all. and when i push the rear brake pedal the light doesn't light up, but it does with the front.
also the turn signal sign on the cluster doesn't blink either?
any suggestion? the wires are all good and i haven't checked the fuse because the marker portion of the light works just not the blinking. the bulbs are all good as well i checked them.
help?
buster09841 is offline
post #2 of 7 Old 04-26-2010, 10:39 AM Thread Starter
buster09841
Anyone?? help!
i checked and fuses are good.
still no blinking and the cluster doesn't show the green arrow either.
Also i have a little flat 2 wire connector at the bottom of my headlight where the main harness and signal wires come out...i have no idea what that is for? any help would be great it looks like this:
retangular, blackish, two wire/connector side by side.
thanks!
post #3 of 7 Old 04-26-2010, 11:17 AM
dcs191919
dcs191919's Avatar
I had the same problem with my integrated taillight/ turn signal. Funny thing is I went to go fix it and all of a sudden it was working again.. Might just be a loose or corroded connection.
dcs191919 is offline
post #4 of 7 Old 04-26-2010, 11:23 AM
Fatalwishes
2007 CBR1000RR
Fatalwishes's Avatar
Check your front brake light......
They should take the warning labels off of everything and let stupidity sort itself out.
Fatalwishes is offline
post #5 of 7 Old 04-26-2010, 02:01 PM Thread Starter
buster09841
Front brake works fine the light comes on when it's pulled. i have checked all the wires and they are all secure.
this is where i'm at right now:
The front signals are on as marker lights but when the switch is engaged they shut off and do nothing. the rear signals just don't do anything all at. the rear brake pedal doesn't make the brake light come on, but the front brake does. and the gauges don't show the signals flashing when they are on. the license plate light works as well, and the headlights work on high and low beam, and the indicator for this works too.
help?!
post #6 of 7 Old 04-26-2010, 03:10 PM
Maddirtbiker1001
Maddirtbiker1001's Avatar
Check the Turn signal relay because that doesnt affect the stagnit light that is on when you r just riding around. and check your foot brake wiring. sounds like a wiring problem with you foot brake pedal
Maddirtbiker1001 is offline
post #7 of 7 Old 04-27-2010, 06:37 AM Thread Starter
buster09841
sounds good i had read alittle about that when i did a search. I think I can locate it fine using the wire diagram in the manual but my question is.
where can i get a replacement relay? is is a specific one or would autozone or a place like that carry something i can use? let me know what it would be called.
thank you!
Human Verification
