2004 CBR 1000rr : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Go Back   Honda CBR1000 Forum : 1000RR.net > CBR1000RR Modifications > 1000RR Mods and Upgrades > Modifications & Upgrades 04-05
Old 12-11-2012, 05:57 PM   #1
2004 CBR 1000rr
So its winter and I am doing some upgrades. I have a jardine slip-on, a power commander 5 with an autotune and a set of air filters on the way. What else should I look at? I am an experienced rider just have never owned a CBR 1000. I bought it and it now has about 16k on it.
Ryntintin2 is offline   Reply With Quote
Old 12-11-2012, 06:01 PM   #2
WFO
ThomAss's Avatar
Maybe 520 conversion with gear change. If it's for the street I wouldn't do too much to it.
2013 Race Sponsors: TrackTactics Trackdays | 717 Racer's Supply | Dunlop Tires | Whoopies Cycles | Whoopies Race School | Vortex | Woodcraft Technologies, Inc. | Agg Racing
ThomAss is offline   Reply With Quote
Old 12-11-2012, 06:03 PM   #3
Yeah it will be a streeter. I was thinking about maybe some gearing because in all reality I am not going to do 180 down the street. Any thoughts?
Old 12-16-2012, 01:56 AM   #4
ROADCRAYON88's Avatar
Just to throw down my two cents. I went /+2 and couldn't be happier. Doesn't help keep front down but smooths out starts. U can always -1/ later.
Sent from my SCH-I535
03' CBR 954RR -repo'ed
04' CBR 1000RR -owned
ROADCRAYON88 is offline   Reply With Quote
Old 12-16-2012, 08:54 AM   #5
DickBlazer's Avatar
520 conversion I like a lot. it gets rid of "feeling and hearing" the chain moving. doesn't add HP but better feel IMO. a little less weight is always nice
'09 Honda CBR1000RR Repsol
'13 BMW HP4
09 CBR Repsol NADA $8865
09 CBR non-Repsol NADA $7605
Difference $1265
DickBlazer is offline   Reply With Quote
Old 12-31-2012, 10:40 AM   #6
Paultheblade's Avatar
Hi. Just to give you my thoughts. I've done loads of stuff to mine and most mods are well worth it. If you can afford it I'd start with sorting out the handling by getting the forks rebuilt (mine have KTECH internals to Superstock spec), an Ohlins rear shock and fitting some race tires. This makes a huge differance and gives lots of confidence. After that you can go for prety much whatever you like. Gearing wise I went for -1 on the front and it has improved the pick up and response....but you should also look at fitting a Speedohealer to correct the speedo too.
CBR1000rr 2005
Lee/Eurobet Race replica bodywork | Ohlins Shock and 2006 link | K-tech Race Spec fork internals | Harris rearsets | Harris tail tidy | Flapper mod | 15 tooth front sprocket | Nicky mod to front sprocket cover | Racetec tyres | Braided hoses | Rear foot pegs removed | Lots of carbon | Powercomander III with custom map | K&N filters | Scorpion end can | Powerbronze rear hugger | Red tinted bouble bubble screen | Acumen gear indicator | Integrated rear light | Pazzo levers
Paultheblade is offline   Reply With Quote
Old 01-27-2013, 03:22 PM   #7
-1 +1 is what I went with and the pick up is awesome
fynix is offline   Reply With Quote
Old 01-30-2013, 11:39 AM   #8
+1 -> Suspension
For $250 drop-in springs & oil in the front and a better shock spring will transform your bike. Youll wonder why you waited.
oblique is offline   Reply With Quote
Old 02-05-2013, 01:31 AM   #9
What's the service record on this bike like?
Splurge on basic maintenance items, new filters, engine oil, fork oil (tho it is now a major pain & full fork removal is required...), pop in new clutch plates + friction discs + springs, brake pads where required, brake fluid drain & refill. Do the spark plugs too while you are replacing the air filters. A new/upgraded chain would not hurt either....unless you are 100% confident with what the previous owner said/did.
Having the wheels & tires looked at is something I highly recommend. Honestly it is probably best to start with new rubber...it is after all the one thing that connects you to the road. Have the bearings inspected/cleaned/lubed/replaced. The steering stem bearings deserve a good looking over, if the previous owner was a huge yobbo & tossed the bike down after a wheelie there will definitely be some premature wear there. Replace with needle bearings if they are toast.
A PAIR block-off may be helpful to you...I suspect that's been done already though.
If you've got bunches of too much $ kicking around you could buy yourself a set of Takai Coil On Plugs...
puretone is offline   Reply With Quote
Old 02-15-2013, 04:47 PM   #10
Wheres a talking service manual when you need one?
