How to: Install a Manual Fan Switch for the 06 - Page 2 : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Go Back   Honda CBR1000 Forum : 1000RR.net > CBR1000RR Modifications > 1000RR Mods and Upgrades > Modifications & Upgrades 06-07
Old 08-27-2012, 10:32 PM   #11
jasonlee's Avatar
I followed "twistingthrottlenz" instructions and everything worked great. I mounted my switch up front instead and found that I could run the ground wire on the fairing support mount. I was pushing about 220 sitting at a light, after the mod I never get above 185.
06 Honda CBR1000rr
05 Suzuki GS500F
jasonlee is offline   Reply With Quote
Old 08-28-2012, 06:35 AM   #12
duke's Avatar
You should go ahead and remove your canister and crap to open more space up. Look it up, its called flapper mod. SUPER easy.
2004 Black Repsol 1000RR w/ some mods
Ex-GF's: '86 Ninja 250, '89 Ninja 1000, '84 Interceptor 500, '01 Erion 929
duke is online now   Reply With Quote
Old 11-11-2012, 07:47 PM   #13
mutilate718's Avatar
explain...canister?? i have done the fan switch and put the switch on top the the middle fairing it was very tight!
''FASTER THAN A SPEEDING TICKET''
cbr1k 07 black, yosh slip-on, Kn fiters, Pclll, goodridge braided lines all around, 2ct's
mutilate718 is offline   Reply With Quote
Old 11-12-2012, 09:56 AM   #14
Makmo's Avatar
I'd like to do the same for my tail/marker lights. I could turn them off when chased and disappear into the night a little easier. More of a novelty for my fantasy but.... makes me happy thinking about it.
Makmo is offline   Reply With Quote
Old 11-12-2012, 10:13 AM   #15
Huge Member
MrDude_1's Avatar
since they're all on one fuse, its easy.
make a wire that goes like this:
Spade terminal --> fuse holder --->long wire-->switch--> long wire back-->spade terminal.
pull the fuse for the lights.
use a meter to find the power side of the fuse holder for the lights.
put the spade terminal with the fuse holder next to it, in the power socket (this is important)
put the other one in the other fuse socket.
now when the switch is on, the lights all work normally.
when you flip the switch, its the same as the fuse blowing... none of the lights have power. (except the headlight, its separate)
if you use a double switch, you can include the headlight while keeping the circuits separate.
MrDude_1 is online now   Reply With Quote
Old 11-12-2012, 12:22 PM   #16
Makmo's Avatar
Sweet. Thanks Dude!
